Idle Knock
Idle Knock
I have a 92 f150 351 and I here a soft knock at idle which goes away if the engine is above idle. I took the belt of and knock is still herd. The truck has about 130k and has been making the noise since about 70k. I always thought it was a bad pully but now I know better. I started listening to other pre 97 ford trucks and many of them have this knock. I was wondering why this is?
Idle Knock
I posted this topic on some other boards and others hear the same noise, some with V8 and some with staight 6's. Some discribe as rattle/knock at idle even with lower miles? I think your right and at idle the oil pump is not puting out the oil pressure required to support the bearings.
Idle Knock
When I first start it there is no noise at all since the idle is higher. When the idle goes down the light knock is heard.If the idle is at 1000rpm no noise is heard. That's why I think it is a problem with oil pressure. My freind's 93 Ford Truck has a 302 and his is making the exact same noise?
