Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-20-2005, 07:18 AM
csramsey640 csramsey640 is offline
Garage is empty, add now
csramsey640 is starting off with a positive reputation.
Other grades of diesel
I saw recently that there are more grades of diesel fuel than what is available at the pump, such as 4,5 and 6 used in large locomotives, turbines, etc. Does anyone know the difference between these grades and reg road diesel?
__________________
Too many vehicles
  #2 (permalink)
Old 04-29-2005, 12:59 PM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Diesel fuels are covered by the ASTM D975-04a specification, which describes seven grades of diesel:
[Grade No. 1-D S15, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 15 ppm.
Grade No. 1-D S500, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 500 ppm.
Grade No. 1-D S5000, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 5000 ppm.
Grade No. 2-D S15, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 15 ppm.
Grade No. 2-D S500, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 500 ppm.
Grade No. 2-D S5000, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 5000 ppm.
Grade No. 4-D, a heavy distillate fuel, or a blend of distillate and residual oil, for low- and medium-speed diesel engines in applications involving predominantly constant speed and load.
Heavier fuel oils Grade 5 and 6 (residual), which are used primarily for heating purposes, are described by ASTM D396.
Find more info here. http://www.dieselnet.com/standards/fuels/us.html
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
  #3 (permalink)
Old 05-17-2005, 01:15 AM
F-150XLT F-150XLT is offline
F-150XLT is starting off with a positive reputation.
There was also once a grade 3 diesel that is no longer in use. Canada has some other system for classifying diesel.
Tags
04, diesel, ford, fuel, grade, grades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
