Cam lift / Rocker arm ratio????
I have been looking for a program that will calculate cam lift and rocker arm ratio. i.e. I have a 496/520 lift cam , and using a 1.7 rocker would result in a higher lift on the valves without changing the cam, but what would the #'s be????? Thats what I've been trying to find. Can anyone help me out here.? Thanks,, Steve
I'm assuming you're talking about a Windsor engine, they have a stock rocker arm ratio of 1.6, so.....
.496/.520 divided by 1.6 gives you the lift at the cam, .310/.325 respectively,
now multiply that by new rocker arm ratio of 1.7 gives you the new lift at the valves,.527/.553
Hope that is what you were looking for.
Originally Posted by Torque1st
Use the desktop calculator that comes with windows or a handheld calculator. Multiply your cam lift times the ratio.
.496 X 1.7 = .8432
-Simple!
.496 X 1.7 = .8432
-Simple!
He didn't specify, he just said "496/520 lift cam". He did not specify what he was working on or what he was looking for. He could have been working on anything from a lawnmower to an industrial engine. The numbers were a little big for a lawnmower tho. Figuring lifts, ratios, etc is easy, -just basic math. No "program" is necessary. You can even do it with (gasp) pencil and paper...
I wasn't trying to be a smart guy, just giving my two cents.
However, I would think since he posted on a Ford forum he was talking about a vehicle and not a lawn mower. The lifts he was giving is a typical lift for a V8 motor. It is also obvious those lift values he indicated would be in reference to "cam lift" and not lobe lift.
Kyle Wood
11-04-2016 02:15 PM
wagonerkl
26
07-25-2011 10:03 PM
fly bye
17
05-23-2010 09:57 PM
flipklos
05-16-2009 09:36 PM
CowboyFromHell
04-22-2009 11:08 PM
