Truck won't start
Truck won't start
How's everyone doing? Got my truck out of the garage this past weekend. Started right up. Went out tonight to go for a ride, fired right up and ran for a couple of minutes and it stalled out. Whent to start it up again and the starter just clicked. I thought battery was dead so i put the charger on and it read full charge. I had no juice to anything, no lights, horn etc. Could i have a short somewhere or could the solenoid mounted on the firewall be shot. I have no idea how old the battery or solenoid is. I did disconnect the battery in case i do have a short.
Does anyone know what the problem could be?
Thanks
Terry
BTW i hope to see some of you at knoxvile next month.
Thanks
Terry
First test Batt( or take it to be tested.. NAPA, Kargen ) Once you know the batts good hook it back up.. Than test for Ground (-) to engine block.. If bad replace ground wire..
If good go and then test Batt (+) to Hot side of solinoid.. If bad replace.. If good test the start side of solinoid.. ( you will need help on this part ) IF good than test the (+) stud on the starter.. if this is hot when the key trun to start than the starter gone.. If not hot when the key turned to start than the cable bad..
I suspect a high resistance connection at some point between the starter and the battery. Disconnect the battery ground and then disconnect, clean, and reconnect the battery positive, both sides of the solendoid, and the starter. You may be getting a high resistance (voltage drop) at one or more of these connections.
