Movement in rear axles - Ford Truck Enthusiasts Forums
Old 10-10-2000, 11:27 AM
dougg dougg is offline
dougg is starting off with a positive reputation.
I just bought a 92 f150 4x4 302 auto supercab. I noticed that I get a shake coming form the rear of the truck when driving. I need new tires so I just thought is was balancing. The other day I had a load in the back and the shaking changed. So I jacked up the back and pulled and pushed on the tires. They would move in and out about 1/16 of an inch. I didnít notice any movement up and down or left to right just in and out. Does anyone have any ideas what this may be?
Thanks
Doug
Old 10-11-2000, 03:19 AM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
dougg, You should have the 8.8" rear end. And from what I have seen this is normal.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old 10-11-2000, 04:04 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
The play is , Like Superdave said ,Is Pretty much normal . If you need new tires or if they dont have the correct pressures this can cause the problems you described .
Old 10-11-2000, 09:37 AM
RGAZ RGAZ is offline
RGAZ is starting off with a positive reputation.
I am with superdave and Paul. If you have the 8.8 rear, which you probably do, the movement is normal. IF it really concerns you, you can have someone open the diff and see if the rubber-rings on the ends of the driveshaft are still intact. They kind of buffer the c-clip that holds the axles on the side-gears of the diff. The play is OK since the c-clips are captured and cannot come off the axles (thank-god) but the c-clip itself can take a beating if the play is excessive. 1/16" is not excessive.
Randy
Old 10-11-2000, 10:08 AM
Thanks All,
Well it is unanimous! It is normal. But, I don't know if I now feel better about it or worse. I would think that on every corner I take it is going to slam. And make it worse. I canít help but think that this is bad. Searching though the post on this forum I have read that axles are known to wear and that there is an ďaxle saverĒ bearing. Could this have any affect on the in/out play? Also how would I find out which rear I have?
Thanks again
Doug
Old 10-11-2000, 11:00 AM
[font size="1" color="#FF0000"]LAST EDITED ON 11-Oct-00 AT 11:00 AM (EST)[/font][p]The axle saver bearing isn't for the problem you describe. That is for the wheel bearing side and has to do with bad bearings.
How do you know it's an 8.8? I don't remember how to tell off-hand, but it is most likely an 8.8 if it is a F-150 (vice a 250 or 350).
Randy
Old 10-11-2000, 02:03 PM
Thanks, Randy
I was just thinking that since the bearing sits in a different location(with axle saver) that maybe it may hold the axle titer.
Doug
Old 10-11-2000, 03:38 PM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
2011 F-150 Shaking in the seats kyle44 2009 - 2014 F150 2 08-19-2016 07:00 AM
Shake Diagnosis 7283-F250 Ranger & B-Series 12 06-05-2016 03:19 PM
bad bed shake on small bumps Eric Mahoney 2009 - 2014 F150 9 04-11-2015 11:13 AM
Front End SHAKES VIOLENTLY ssolid Excursion - King of SUVs 18 03-10-2014 01:23 AM
Ball joints, maybe? vibration, shaking feeling wolfmanagh 1999 to 2016 Super Duty 15 08-31-2006 10:16 PM
Tags
1986, 88, 92, axle, bearing, end, excessive, f150, ford, isuzu, jacked, play, rear, rubber, saver, trooper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
