Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-19-2005, 03:16 PM
LoosMaster's Avatar
LoosMaster LoosMaster is offline
LoosMaster is starting off with a positive reputation.
Intermittent Miss
I'm registered on this forum and usually hang in the V8 section but I have a Mustang with the 2.3 and it's common on the Ranger. Need some advise on troubleshooting this miss. I have no codes, no lights other than a defective SRS system that's been disabled. This started a few days ago. Happens when engine is cold and after running for about an hour it goes away for the rest of the day until the next morning when engine has time to cool off. It accelerates fine but between 1500 and 2000 there is a miss like a cylinder is cutting out, you can see the tack drop about 200 rpm back and forth. When the engine reaches a no load the miss goes away. If you ever so slightly touch the throttle it starts again until the engine unloads. I've changed the coil, TP and the MAP, the plugs, wires, rotor and cap were changed about a month ago. I've cleaned the throttle body and ran some SeaFoam in the tank. Nothing. I'm going to change the EGR valve next. I have a new TFI but can't figure out what size socket is required to take out the bolts. I have a ***** load of tools and nothing fits. This is on a 1990 Ford Mustang LX with the 2.3L engine, I also have another that's a '92 which is a donor vehicle, except the ignition components. Thanks in advance.
__________________
"Massive Project"
'88 Ford F150 4WD
351W EFI Engine('90)
ZF S-42 5 Spd
2.73 w/31" Tires
'92 Ford F150 XLT
Extended Cab 2WD
5.0L EFI
Auto(E4OD)
  #2 (permalink)
Old 04-20-2005, 08:39 PM
LoosMaster's Avatar
Well I found out today the TFI uses a Torx tip special tool to remove the screws. I replaced the EGR valve yesterday and the miss went away. Not sure if the SeaFoam finely kicked in but there was no miss at all. The old EGR valve was completely jammed shut with carbon. So, hopefully if anything, it will start to get some better gas mileage with all these new parts. I droped another can on SeaFoam in it with a tank fill up just to make sure.
__________________
"Massive Project"
'88 Ford F150 4WD
ZF S-42 5 Spd
2.73 w/31" Tires
'92 Ford F150 XLT
Extended Cab 2WD
5.0L EFI
Auto(E4OD)
  #3 (permalink)
Old 05-20-2005, 04:13 PM
LoosMaster's Avatar
Well, the miss is back. I put on a new TPS, it has better throttle response now but still the kicking at 1500 to 2000 RPM like a miss. Checked the fuel pressure and it's 38lbs with key off, 32lbs engine running. I let it sit for almost an hour and only lost 2 psi on the guage.
__________________
"Massive Project"
'88 Ford F150 4WD
ZF S-42 5 Spd
2.73 w/31" Tires
'92 Ford F150 XLT
Extended Cab 2WD
5.0L EFI
Auto(E4OD)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
