96 5.8 bronco went on a 780 mile trip/ how hot does your 5.8 run?
the lady that takes my money at wal-mart tells me "that they gas burns faster"............and i must bust a-lot of eggs - This debate will never end - yeah, my 96 w/5.8 and 10" rims w/32"er's gets 11 most of the time. I use OD when pullin light loads on level ground such as the pop-up camper, not the bogg truck on the trailer.
Did i mention my '79s avg 10
and yes, i could not tow around excess pounds, then again i woodn't drive a bronco if that was the case.......
jbronco - you're on ta something.....you rock
you say if i tow in OD, i should keep up enough rpms. well what is that rpm i should try ot keep it at? when i drive in OD i'm at only 1700rpms going 6500mph. and 1850 going 70mph. so i am not sure if thats enough rpms to be pulling.
in california i can't tow faster than 55mph anyways. if i were to use OD at 55mph, i'll only be turning 1500rpms or so. that enough rpms? i would assume now. if i had OD off, it would be 2050rpms going 55rpms.
as soon as i hit nevada and utah, they don't have trailer towing limits. so i guess 1700rpms is enough to turn then i'll tow in OD only when i can.
however, i'd still have to control the distance cuz the dolly won't have brakes. i maybe be able to use dad's at his work with drum brakes though.
Like I said, I have done it many times and had no trouble. If you do it right, and are towing semi-light loads like 2,000-2,500 pounds, then you will be fine. But just recall that most of the manufacturers, and most of the people that you talk to will tell you NEVER to tow in OD. So if you are not sure of yourself, don't do it. But if you feel comfortable with it, and don't feel like driving 2,500 miles with the OD off (especially with today's fuel prices) then you can consider that I have been doing it for over twenty years and have not burned up a transmission yet, or had a dangerous towing situation caused by towing in OD. Just don't do it unless you are a capable enough driver to know when you can be in OD and when you should not be in OD; whether towing or not.
when towing you want the motor to be operating in its power range. anything below 2000rpms will be below its power range causing the motor to work harder to maintain speed thus using more fuel. if your towing good rpm range is 2200-2600 for optimal power/mpg. towing 2000lbs is not much weight at all. most cars by themselves weight over 3000 then figure weight of dolly which is probably between 500-1000lbs. for an AOD tranny towing in OD is bad, with an E4OD its Marginal but if the tranny does go an e4od will cost 2k + to have rebuilt. so like jbronco said use your best judgement. also remember that running tires larger then 31's on stock gearing will increase the stress on the drivetrain unless rpms are kept up.
Yup use your judgement, if it feels right do it, if it don't, then don't! When I am towing in OD it's more like just coasting, there is no strain on the engine at all, and I probably even have it in cruise control. And like the man just said as well, 2,000-2,500 lbs is not a lot. Were I pulling 5,000-5,5000 then I doubt that I would be able to hold it on OD, and it could be harmful to even try. If I thought for even a second that the OD towing for the U-Haul trailers was causing any harm at all, I would not do it. But I think that 20+ years of doing this without a hitch (pun intended) bears me out, at least for U-Haul-type trailers.
YOu get better mileage than I do....I have a custom grind mild cam...roller rockers, Edelbrock heads, ported intake, JBA headers and Bassani Y pipe with the flowmaster exh....I did however see a 1.2 mile per gallon increase with the combo when taking it easy as compared to the stock setup.
Exhaust and air filter really help.
measurements are an average after a year of calcs.
west6767
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
06-27-2017 08:00 PM
annaleigh
12-27-2015 08:35 PM
