2.3-Putting the turbo onto a stock engine
Say this ebay auction. Would something like this, if installed, it would work right? Or would I need a different computer?
Have a sand blaster, so they will all be cleaned up nicely.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
As a owner of a 87 T-BIRD TURBO COUPE ( GOD I LOVED THAT CAR) and MANY V-8's FELT THE STING !!! The bottom end is differant in a standard 2.3L. L@@K around in the local junk yards !!! you'd be surprised as to what you might find !!! At mine i could get you a FACTORY TURBO CHARGED 2.3L for $150.00 !!!!! They come around OFFTEN !!!! For 1 buck and a half ??? how can you go wrong ???? WRENCH on ONE WHILE you DRIVE THE OTHER !!!! COOL CONCEPT !!!!
If you really want turbo, take 351cj's advice and get a 2.3t donor to swap instead of trying to turbo your n/a 2.3 ... the n/a 2.3 has a considerably weaker bottom end with cast pistons that can't handle very much boost where as a 2.3t has forged pistons and can handle the boost you want. overall, the swap would be much cheaper than trying to convert your n/a 2.3 block
With the turbo engine, how hard is it to put into a newer (93 up) 4 cyl truck with auto?
Will it compete with the V6 in the towing category? I am selling the current truck and buying a newer one, was looking for a v6, but may go 2.3 turbo route?
Object to be towed is about 3-3500 lb, and has brakes.
on
I have heard that you can put a turbo on a stock 2.3 if you reset the wastgate to dump the excess boost at a lower pressure than normal, and then baby it. (Yeah right, then what's the point?)
I have two 2.3 turbos sitting on my shelf, thought I might build a turbo motor at some point. A buddy used to race the 2.3 and still has a lot of parts, forged pistons and such. Last time I checked he still had a couple of turbo blocks, but that's no big deal, easy enough to modify a stock block for turbo oil drainback. Someday maybe, when I have a few more projects behind me...
If you want to tow, cubic inches are the way to go. A turbo (originally) was designed to be used as an acceleration tool, and not for continuous use (like towing 3/5k). I'd think you'd want a 4.0 for the low end torque to get you going. Plus, the turbo came on stick trans, and you'd be replacing the trans every time you turned around if you stuck a turbo in front of an A4LD (or any other trans expecting 2.3/2.5 torque output). The blocks are all the same, the mains and rods vary over time, and the holes bored differ based on ignition system used.
To reiterate, don't turbo a base 2.3 unless you are going to use it very sparingly, and that is not the case for towing...
tom
tom
Can't argue with that. I know nothing about nickel content, but most late model 2.3 engines were not only cast in Brazil, but assembled there also.... and it was not Lima, Brazil.
I was unaware that there was a different casting number or part number for the turbo block. Do you have either one or both? Might be a nice thing to know if andwhen I go junk-yarding for a turbo. Don't want to get stiffed by someones 'home built' conversion, or incorrect block replacement.
tom
tom
