Cam and Crank Sensors
Greetings,
I'm attempting to graft a 4.6L Mod motor's EDIS to something else.
I have the two sensors, and I managed to find a diagram of the crank wheel, so I'm set there.
The mystery is the cam sensor... does the cam sensor point to a toothed wheel cast into the camshaft? or is it a seperate wheel? Any details of this particular "thing" would be most appeciated.
Fabrication on my part is fine, I really just need to know the number of teeth, where they are, and which way it points as I imagine it's keyed like the crank sensor.
Thanks in advance!
Regards,
Frederic
Thanks in advance!
Regards,
Frederic
The crank sensor wheel has a missing tooth setup (35 teeth and one missing). The cam sensor sits over the driver's side cam gear. There is a bump in the gear close to the hub that the sensor picks up. I'm unsure if it is threaded into the cam gear hub or if it is in fact cast in. There is no extra sensor wheel though.
