BioDiesel
On our '97 F250HD and on the '82 Mercedes turbodiesel, I left them running while pouring B100 into a half-full tank. You could *clearly* hear when the biodiesel made it through the system up to the engine. The diesel "clatter" nearly disappeared! It's amazing how much quieter they run with a decent blend of biodiesel. Not sure if B2 or B5 would have that noticeable an impact, but it does boost the cetane rating pretty dramatically, so it just might quiet it down.
Duncan
Duncan
The mix I use (which is above) is running about 8 - 10 cents more than #2. Depending on soyoil futures etc. and your local tax base for biodiesel. And your question on soot. I have nearly none in the tailpipe. So I am assuming that this will be no problem for the egr and probably will help
tried to copy an article from a website but it is locked out for copy and paste. go to www.forddoctorsdts.com then go to articles. look at the fuels article and egr article. they didn't have anything on the injectors
I found on the ford fleet site under environmental - that there are technical questions they have using biodiesel over 5%. Questions like seals, metal fatugue, etc.
Found on John deere site that if you use over 5% that there might be a (what they call ) a coke problem with injectors.
Ok guys here are the specs on the fuel I use direct from the company. With a #2 comparison as a baseline....
.................test procedure ,,,,,,,,,,,,,,,,,soydiesel XC,,,,,,,,,,,,,,,,,, #2 diesel
cetane (engine test) ASTM D613,,,,,,,,,,,,,,,,,, 51.3,,,,,,,,,,,,,,,,,,,,,,,, 41
CETANE INDEX (GRAV,) ASTM D4737............. 46.9................ NONE LISTED
COLD FILTER PLUG POINTASTM D6371 ..........-21F....................... -10
CLOUD POINT ASTM D2500 .........................+3F...................... .... 0F
API GRAVITY ASTM D4052 ..........................34...................... ...... 32
VISCOSITY ASTM D445 .............................3.3.................. ......... 3.0
FLASH POINT ASTM D93............................ 180 .........................140
COPPER STRIP CORROSION ASTM D130............. #1....................... #1
DISTILATION IBP ASTM D86.......................... 365........................ 360
E.P. .................................................. ........655........................ 665
RECOVERY % .................................................9 8........................ 98
RESIDUE % .................................................. .1.0........................ 1.0
SULFUR % .................................................. ..05......................... .05
Hope this helps and hope my chart looks right on the net. Nope it won't let me put in spaces to make a chart......
here is the web site https://www.crystalflash.com/files/C...iesel%20XC.jpg
#29
Just got 5 gal of BioDiesel for $35 from Taylor Oil CO. INC base out of NJ but i got it from a guy here in Portland Ct. Will see how it works. Let see 29 gal tank (say 30 )and 5% of that would be 1.5 gal so will start with just 1 gal and that will be just about 3%.
The cetane level on the side of bucket said 52.7. and I get diesel at the truck stop that says min 40 cetane and 1 8oz one shot from Stanadyne.
Ok sound good will let you guy know how it works out later John
