Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-13-2005, 08:42 AM
cjric cjric is offline
Garage is empty, add now
cjric is starting off with a positive reputation.
heating oil in my diesel?
I just took a tank out of a basement w/ 50-75 gallons of OLD heating oil in it. Im wondering if I can run this in my diesel (99 jetta TDI). I will be filtering it first, to get rid of any debris and growth, and probably mixing it with the B-20 that Ive been putting in my car.
Does anyone have any experience/opinions with this?
  #2 (permalink)
Old 04-13-2005, 09:19 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I had a couple hundred gallon of heating oil in the basement of a house I owned that burned, and noone would come take it out, so I did it myself and ran it through my 86 F250, no problems. It is dyed, so actually illegal for road use, so be aware of that.. I haven't ever been busted for it, but know of some that have. Basically all the heating oil is is #2 diesel with red dye in it.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 04-21-2005, 03:52 PM
hydrosmith's Avatar
hydrosmith hydrosmith is offline
hydrosmith is starting off with a positive reputation.
Also your heating oil may or may not be high sulfur if that would be of any concern to you. But yes heating oil and diesel are two names for exactly the same thing.
__________________
Tim
'1969 F-250 C/S,390 2bbl. Duraspark II, C6, 3.73 Dana 60 Custom cab
1996 Bronco XLT 351
WASHINGTON CHAPTER MEMBER
  #4 (permalink)
Old 05-17-2005, 01:19 AM
F-150XLT F-150XLT is offline
F-150XLT is starting off with a positive reputation.
High sulfer diesel can damage injectors. I know that some construction equipment can run on high sulfer diesel.
Tags
69, diesel, engine, heating, home, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
