351m motor - Ford Truck Enthusiasts Forums
351m motor
Old 04-13-2005, 07:48 AM
redneckhotrod redneckhotrod is offline
redneckhotrod is starting off with a positive reputation.
351m motor
I am looking too rebuild my 351m with Clevland heads, i would like too get at least 420 horse out of the motor it is in a 78 f150 4x4 club cab need all the help i can get this will be a hot rod when im done thanks.
Old 04-14-2005, 10:27 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Not with a 351M it won't. The stroke is too short for adequate torque, the rods are too long, and the pistons too heavy, to get the RPM's for 420 HP out of it. The 351M is a low speed truck motor. If you want to build a hot rod 351 stick with the 351W. You could build a Cleveland but parts are scarce and $$$.
Old 04-14-2005, 03:25 PM
GreenSubmarine GreenSubmarine is offline
GreenSubmarine has a good reputation on FTE.GreenSubmarine has a good reputation on FTE.
I dislike use of the word "impossible"; but Torque's right. 420 horses is a long way (read: tons of money, maybe impossible) from where you're starting. If you're gonna do a full rebuild, you can change your crank and pistions, and start with a 400. You'll spend some money making 400+ horses with a 400, but it is entirely possible. A 400 has plenty of torque when built, so it would be great for your truck. But if you mean hot rod as in racing, there are other engine choices that may be better suited to that application.
Good Luck,
Ernie
Old 04-14-2005, 08:41 PM
1979ford's Avatar
1979ford 1979ford is offline
1979ford is starting off with a positive reputation.
Are you planning on using 4 bbl Cleveland heads? The heads on your 351M are the same as 2 bbl clevelands.
Old 09-30-2007, 10:04 PM
Eddie A Hill Eddie A Hill is offline
Eddie A Hill is starting off with a positive reputation.
Talking Hot rod 351 m 1978/
Quote:
I OWN ONE 1978 4x4 with a soon to be 400 hp+ 351M 400 one main key is
Edelbrock ALUMINUM Heads part#61629 &a head bolt kit.call edelbrock
for thear recommended intake & carburetor it is way cheaper than crate engines. And moor FUN puting it all to gethar and making it work right.
351 M's are thunder thumpers ready to go fast in the mud.
Bell Housing 351M to 351W pech33 1973 - 1979 F-100 & Larger F-Series Trucks 14 01-17-2011 03:45 PM
351M to 351W swap oldschool_77 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-15-2010 11:12 PM
What a deal! Question about bore size also. chief2007 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 10-16-2007 12:33 AM
351 motors boss4x4 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 64 07-01-2002 01:18 AM
PAW Super Stock Crank Kit 77_F150_4x4 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 08-20-2000 10:11 PM
Tags
351, 351m, builf, carburetor, cleveland, crate, engine, engines, ford, good, heads, moter, motor, race, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
