Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-12-2005, 06:03 PM
AxelStone AxelStone is offline
Garage is empty, add now
AxelStone is starting off with a positive reputation.
96 Ranger, rough engine at odd times.
Just bought it, not familiar with twin spark 4bangers. 96 Ranger, engine has probably 90k miles on it. It seems to run rough at idle, get it up to about 3k RPM and it feels like it smoothes out. A/C running does not affect the drag on the engine. Has good pickup, I dont have it road legal yet so have driven it approx 60miles total up to 75. Feels like it run smooth at 75. Also, mechanic told me no compression in the 4th cyl... I somehow doubt that with it running smooth at higher RPM. Plus the engine does not shake at idle, just runs rough (but never stalls even at idle)
BTW: Checked firing order and it was correct, cat was removed by previous owner. Someone mentioned something about O2 sens could be causing this?
Any starters? Mechanically inclined, know more than enough to keep myself out of trouble, just not much of a gearhead.
  #2 (permalink)
Old 04-12-2005, 08:41 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #3 (permalink)
Old 04-12-2005, 08:50 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE !
Is the service engine light on?
There's 2 plugs that are nasty to change on the drivers side. How old are the plugs?
The throttle body could be dirty. This usually shows at idle.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #4 (permalink)
Old 04-13-2005, 10:09 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
With what Dealford brought up, I BET the last plug or two was not changed and that's how the rougness is noticeable until you get up to highway speeds.
The cat should not have an effect. An oversized exhaust pipe would slow the flow down enough to "plug" things up in a sense which would be trouble.....but that must not be the case here.
  #5 (permalink)
Old 04-22-2005, 08:17 PM
Well odd thing, replaced the Air Control modual and cleaned it up abit cept under A/C was about as bad. Compression test comes back with 80lbs instead of the norm. So i'm thinking burned valve. Sound bout right?
  #6 (permalink)
Old 04-23-2005, 08:46 PM
Dealford's Avatar
Well, that puppy won't be barkin' on all 4.
Did you squirt some oil in the cylinder and check the compression again to confirm valves as the problem?
This may be your chance to re-ring & bearing the bottom end cheap after you freshen up the head.
AL.
__________________
Tags
1996, 23, 96, engine, feels, idle, idling, low, missing, ranger, rough, running, shakes, shaking, smoothly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
