Disable Door Autolock feature - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-11-2005, 01:10 PM
palindromelol palindromelol is offline
palindromelol is starting off with a positive reputation.
Angry Disable Door Autolock feature
F250 2002 4x4 supercrew
The truck has, what I consider to be, a very annoying feature. If the doors are unlocked at start-up, they will auto lock when you back-up or pull away.
If I want the doors to be locked, then I would lock the doors. It aggrivates the heck out of me that it does this automatically. I found and implemented the seat belt chime disable method (thanks FTEs), now I would like to disable the auto lock at drive away. I want to still keep the power lock feature and the remote lock/unlock. I just don't want it to auto lock.
Mr Ford. I hope you have your engineers read this site.
Old 04-11-2005, 01:27 PM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
I am fairly sure that there is a process to change the programming of the door locks and security system. If it is not in your owners manual, check with the dealer. It is a process of turning the key on and off and taking a second step before the horn honks 4X for one of the programs, 3X for another program and so on. Our Rangers do not have power door locks but it seems to me that we changed the programming in one of the sedans three or four years ago for the same reasons you stated.
Let us know how it works out.
Russ
Old 04-11-2005, 03:08 PM
phil350 phil350 is offline
phil350 is starting off with a positive reputation.
I know the 04's have a procdure to disable the auto lock feature and the seat belt warning chime. The lock involves the ignition and the lock button in some sequences. It is the first thing I did. The procedure was in the manual. Good luck ont the '02.
Old 04-11-2005, 03:49 PM
Well phil350, you are correct. For 2002 F250, the Autolock disable/enable feature is on pages 89-90 of the manual.
Thanks Phil350 and Rangerruss.... It has been successfully disabled.
Pal
Old 04-11-2005, 11:31 PM
Hooray! Happy to hear that you were successful. The automatic stuff can be annoying.
Russ
Old 04-12-2005, 05:21 AM
missouguy missouguy is offline
missouguy is starting off with a positive reputation.
I don't mind the autolock, but I wish when I put it in park they would unlock like my Buick does. On the car my wife has it programmed to unlock only the drivers door, I have it open all of them. Wish Ford would have a similar arrangement on the trucks.
Frank
Old 04-12-2005, 06:05 AM
Greg 79 f150 Greg 79 f150 is offline
Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.Greg 79 f150 has a great reputation on FTE.
hmmm, lets see now, why would anyone design auto lock doors anyway ??
Might come in handy for children to not being able to accidently or purposely, open the doors while the vehicle is moving. Or,
When a woman is driving, and forgets to lock the doors after each stop and go errand, its nice to know that she has autolocking doors. That way , as she pulls up to a traffic light, a big, mean, perverted individual cannot just quickly open the passenger door , get in and put a gun to her head , as a result of her not having locked doors. ..
Always some inconveniece to safety measures, it is a tradeout, as to how much gambling on safety a person wants to take. One person may use autolocks for 20 years and never need them for the above reasons, for another person the feature may have saved their family some real misery on just one occasion, and they would love that autolocking system for it.
Old 04-12-2005, 12:18 PM
lmooreF250 lmooreF250 is offline
lmooreF250 is starting off with a positive reputation.
Palindromelol,
I have a 02 F250 and read the manual but the procedure in the manual did not work. What was the procedure in your manual? Also the manual says the truck will unlock the drivers door if you acidentaly shut it with the engine running but mine stays locked, I've been carrying around 2 sets of keys because I know I am going to slam that door shut and be locked out. Any sugestions?? Thanks in advance
Old 04-12-2005, 05:42 PM
ImooreF250,
I did this, verbatum from my manual....
1) Ignition off, all doors closed.
2)All within 30 second do,
2.1) ignition on
2.2) power door UNlock 3 times
2.3) ignition OFF
2.4) power door UNlock 3 times
2.5) ignition on (Horn should Chirp)
2.6) power door Unlock 1 time
2.7) power door LOCK 1 time (horn should chirp)
2.8) ignition Off (horn should chirp)
It worked fine. F250 Lariat supercrew 2002 5.4L 4X4
Pal
Old 04-12-2005, 07:46 PM
I have tried to disable this feature but it won't. Did your door lock when the key was turned to the on position? As soon as I turn the key on the doors lock. So I'm not sure to wait for the doors to lock then press the unlock button or just do it when the key is turned on and then when the key is turned off the doors unlock. I have tried it both ways waiting and not waiting. I get it done under 30 secs but can't get it to stop locking the doors when the key is turned on. The manual says the doors don't lock until the truck is moving but not mine, they lock right away. Anyone heard of this? Any help would be appreciated. I know I'm going to start the truck and shut the door so I need this disabled Thanks
Old 04-12-2005, 09:26 PM
I do not have the same autolock problem. Mine autolocked upon vehicle motion. I have the grand experiance of 1 F250 truck. Sorry.
Old 04-13-2005, 12:37 AM
Quote:
Mine is that way also, it doesn't lock the doors until you reach 5 mph. I like the feature so I haven't tried to disable it. My drivers door will not stay locked if the key is in the ignition, I haven't tried it with it running.
Frank
Old 10-02-2006, 04:09 PM
bretmartin bretmartin is offline
bretmartin is starting off with a positive reputation.
Mine does the exact same thing. As soon as I turn the key on, the doors lock. I have tried the procedures that are all over this forum, but it does not work on my 99 F-350. I have had a 03 and an 06 and both of them did it when it started rolling, and this procedure worked for the rolling thing, but not the key up. If anybody has a remedy for this, please share. The doors lock immediately when the key hits the run position.
Old 10-03-2006, 01:09 PM
kb1aah kb1aah is offline
kb1aah is starting off with a positive reputation.
Just a guess but you guys that are experiencing the immediate door lock, it could be caused by an aftermarket alarm system if you have one installed. I have had a couple aftermarket alarms that included keyless entry and if programmed to do so they would lock the doors as soon as the key was turned on. If this is the case it has to be reprogrammed through the aftermarket alarm box and not the trucks own system.
Hope that might help.
Old 10-03-2006, 05:20 PM
Spamjohnson's Avatar
Spamjohnson Spamjohnson is offline
Spamjohnson is starting off with a positive reputation.
Yep, the PO of my 99 had a Viper alarm installed, he was kind enough to send me the manual to the alarm when he found it 8 months after selling me the truck. (How about that for a good SD owner). I went through the manual and deactivated the door locks. I'm glad there are auto lights and auto hubs and vacuum ***** on the dash, just let me have the option ok?
Sam 99350PSDCCLB
auto lock disable jocko165 1999 to 2016 Super Duty 7 10-26-2015 07:36 PM
Automatic Door UN-Lock - Is there a bypass? SturgeonHunter 1999 to 2016 Super Duty 3 01-06-2014 03:41 PM
2008 f150 crew cab auto door lock disable tankd72 2004 - 2008 F150 4 10-11-2009 12:33 PM
Turn off auto door UNlock feature? GroundhogCK 1999 to 2016 Super Duty 13 11-02-2007 11:14 PM
Are you tired of the auto lock feature? garymake 1999 to 2016 Super Duty 12 09-15-2003 11:11 AM
Tags
2003, auto, autolock, disable, door, enable, f150, feature, ford, lock, locks, power, sport, system, trac, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
