Vacuum Leak
Vacuum Leak
While I was replacing a heater hose today, I shut the truck off after testing and heard what I thought was a vacuum leak. A small buzzing sound that petered out after 20-30 seconds. Since my '88 F-250 460 has a maze of vacuum hoses on top of the engine, is there any easy way to locate it?
Thanks in advance for any help you can give,
Paul
Paul
Vacuum Leak
Being as this is associated with the replacement of the heater hose, I would begin my search by checking the vacuum cannister that sits on the fender under or next to your heater hose. The cannister builds up a reserve to run the vacuum controled heater or a/c doors. It's very easy to knock the vacuum hose off the cannister and cause a leak.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Slik
d00g13
06-22-2014 05:20 PM
paulm
11-30-2009 02:38 AM
