Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-10-2005, 11:20 AM
Scoarch Scoarch is offline
Scoarch is starting off with a positive reputation.
Tips And Tricks
Hi all.
i just wanted to start a post on tips and tricks anyone may have .
specifically on 73-79 trucks.
there are probably a lot of people that have something to share.something new 73 - 79 owners might not know.
like rear glass from 73 to 96 fits.
Or that seats from up to a 96 are bolt ins
just want to pick all your brains really
__________________
78 f150 Ranger shortbox
460 out of 76 couger xr7
4 inch suspension
on 36's
  #2 (permalink)
Old 04-10-2005, 11:31 AM
Djoffroad's Avatar
Djoffroad Djoffroad is offline
Djoffroad is starting off with a positive reputation.
How about Chevy front 4x4 axle shafts will fit the Fords.
  #3 (permalink)
Old 04-10-2005, 11:44 AM
Now thats what i am talking about.
Lets keep them comeing
__________________
4 inch suspension
on 36's
  #4 (permalink)
Old 04-10-2005, 06:02 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 is starting off with a positive reputation.
dang! beat me to the seats!
turn signal lenses from 80's econoline vans fit our pickups, but are clear instead of amber.
I will probably think of more...
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
  #5 (permalink)
Old 04-10-2005, 11:21 PM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
tail light lenses from 75-92 econoline vans work in our trucks as well.
also the locking hood latch from these same vans are 100% interchangeable with the 73-79 locking hood latch, the only problem is the length of the cable is too short on the vans...
  #6 (permalink)
Old 04-18-2005, 03:06 PM
Phideaux Phideaux is offline
Phideaux is starting off with a positive reputation.
TIP: Tranny Tailshaft rear motor mount through bolts should not be tightened more than 10-15 Ft. Lb. This mount needs to "flex" and pivot. Use a grade 8 through bolt with a Ny-Loc nut.
TRICK: To keep from losing your mind while trying to keep a torque converter in place while you're lining up an automatic transmission to the engine, use a 3/4" or 11/16" combination wrench lightly bolted through the lower transmission case mounting hole (closed end part of the wrench) with the open end pushing up against the torqe converter. When you're satisfied with the line-up and just before the gap beteween the engine and transmission closes up, remove the wrench. One more push and, yee-ha, it's in.
J.
  #7 (permalink)
Old 04-19-2005, 07:41 AM
four-sixty-power's Avatar
four-sixty-power four-sixty-power is offline
four-sixty-power is gaining momentum as a positive member of FTE. four-sixty-power is gaining momentum as a positive member of FTE.
The hood latch in grille is adjustable, adjust it and amaze your friends when you can actually "pop" your hood, give it lots of lube after adjustment. I hate seing these trucks with the lever bent halfway over cause the idiots before me didn't know how to care for something properly, just remove 2 bolts and bend handle straight with hammer and bench vise, lube, paint handle, reinstall properly, done!
when you first get the truck replace all the old vacuum lines with new, it felt liked I gained 30HP just from better vacuum!!! and my rpms dropped too! make sure to replace one at a time so you don't mess up the routing.
when you first get the truck:
change out the air filter, pcv filter, fuel filter, power steering filter if equipped, check/replace plugs and wires, replace cap & rotor or check/adjust/replace points, check/adjust timing, make sure you have good ground wires to bat and alt, block to frame, and body and frame. replace oil & oil filter and check trans fluid level. do that and have fun and get to know your truck and you might find something you misssed before you bought it.
It does make a performance difference, response is crisper and mileage is better.
In the inside on my two tone jade green truck, I changed to tan interior, but for the door panels I put the dark green armrests on the tan panels, looks sharp and slick and better than stock using stock pieces, simple & looks NICE!!! have to remove door panel and on back of panel undo two screws holding armrest to panel
I have bucket seats from a 83 datsun Z or something(free from friend), me & dad welded a custom frame for them and they look sharp! tan leather 4-way mechanically adjustable, I love lumbar support! I wanted head rests was the main reason, but I like how they keep me from sliding in the corners!!
Use anti-seize compound on any bolt or screw that is exposed to the elements that you have to remove and replace.
If you want to use clear turn signal lenses in front, buy some amber bulbs to go inside of them so you are still legal, not many people like a glaring strobe light to distract them.
lube/grease your hood hinges, made a world of difference on mine.
EVERYTIME you wash your truck, wash out the hidden lip on the rear wheelwells so they DO NOT RUST OUT!
don't use front chrome bumper as step to work in eng bay, you will scratch it, and it will be noticeable
you can get chrome plated(shiny) door lock pulls off of 73-96 Ford trucks and probably vans too
haven't tried it yet, but I was thinking about getting the bigger sun visors out of a van for my truck
the 73-79 doors have a stock 6 inch round speaker location hidden behind the panel, look before you cut!!! It ticks me off everytime I see one in a wrecker, a 6" speaker below the panel, I pull the panel to find an empty stock hole. They ruined a door cause they didn't look behind the panel. Easier to replace/fix a panel then weld a hole in the door!!!!!!!!!!
just because it is a 30 year old truck doesn't mean your friends should slam the doors with all their might!!! politely tell them not to do that, or let them walk home from the mall or wherever.
I repositioned where my window crank handle rests when closed and open so my knee can rest comfortably against the door panel.
If you look carefully in the wrecking yards you can find the armrest/handle piece, that looks like a strange canoe when removed, in plastic or metal, the plastic ones break if abused, the metal ones don't and you can paint them easily.
make sure to use that round opaque plastic spacer between the door panel and the window crank handle, it makes rolling down/up the window a little easier and doesn't damage the panel(and the spring between panel and door cuts down rattles, if equipped)
there are 9 clips holding the panel to the door, one screw on the door open handle, one screw on the window crank handle, two screws in the armrest/pull, and then the door panel comes off
the headliner is ridicuously easy to get out to replace or customize
try to find chrome headliner strips in wrecking yards, they look better IMHO
I think that plastic cover piece at each end of the benchseat that breaks often is interchangeable 73-96
for the benchseat itself bolting in, you have to use your 73-79 seat mounts/rails on the 80-96 benches, the rails easily unbolt from all 73-96 benchseats
my driveshaft is greaseable, check if yours is if you hear a clunk, and even if you don't
I used the hood to cowl rubber weatherstripping off of a mid80s ford van in my beater truck but I had to drill 2 holes for it to fit, be careful when removing, it breaks easily.
use anti-seize on your lugnuts
a lockable glovebox is a nice thing to have, search the wreckers and have a key made at a locksmiths place, doesnt cost too much when you bring the lock to them
clean the radio antenna for a better reception - it relly does work! just use something that doesn't leave a residue behind
theres a little tab on the bottom of the plastic guage/heater/radio surround that I always forget to pop in before I put the 1st screw in place and have to redo it
I'm done for now, enjoy!
__________________
Be Careful
Be careful of your thoughts
For your thoughts become your words
Be careful of you words
For your words become your actions
Be careful of your actions
For your actions become your habits
Be careful of your habits
For your habits become your character
Be careful of your character
For your character becomes your destiny
author unknown
  #8 (permalink)
Old 04-19-2005, 01:11 PM
wow, that was like, long. but some really great info
__________________
  #9 (permalink)
Old 04-19-2005, 04:54 PM
GeneStoner GeneStoner is offline
GeneStoner is starting off with a positive reputation.
Not all steering wheels that FIT on our trucks will actually operate the horn and cancel the turn signals. Caveat Emptor...
  #10 (permalink)
Old 04-19-2005, 05:26 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
When installing an aftermarket stereo, don't run wires over to the fuse box. Use a male spade terminal in the factory radio connector for switched power. The connector for the lighter harness is just to the right, and has open spots for your constant 12v wire.
I plan on using the other side of the radio connector, which comes on with the dash lights, for guage lights. This avoids tapping into wires or the headlight switch.
__________________
1997 F-250 Supercab 4x4 7.3 PSD ZF 4.10 169K pics
1995 F-150 Supercab 4x4 5.0 M5OD 3L55 251K (daily driver) pics
1995 F-150 Supercab 4x4 5.0 (#2) 4R70W (weak but original) 3.31 333K (rusty work truck) pics
94 F-150; (2) 78 F-150 4x4's; 79 F-150 4x4; 79 F-150 302 EFI; 79 Lincoln Continental
  #11 (permalink)
Old 04-23-2005, 01:40 AM
Grille trick
Just because you have a cracked grille or a chunk missing out of one, doesn't mean you have to run out and buy a new one(or half of one). When you remove the damaged grille see how much you can move the crack, probably not much. Just get some duct tape and line up the crack and then tape it straight. Flip the grille over so you can see the back of it, its kinda hollow. You want to buy some fibreglass that you mix up, so you can pour it into that kinda hollow space to fix the crack, but you might want to rough up the surface a little first, and its probably good to use some mesh in there too. Wait for it dry a day or two depending on how much you use(the guy that told me this said he just fills them to the top)and take the duct tape off. If you have an obvious line where the crack was, just sand the crack to open it a little and spread some fibreglass over the area and when dry go ahead and sand it and paint it.
The same applies if you have a chunk misssing from it, just make a little form of cardboard, then duct tape the form to the grille and fill from behind.
-EDIT- More suggestions:
http://www.ford-trucks.com/forums/sh....php?&t=417087
__________________
Be Careful
author unknown
  #12 (permalink)
Old 04-23-2005, 03:51 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold Torque1st is a splendid one to behold
The 351C/M/400 takes a special thermostat with a kind of collar around it. A 192-5°F thermostat is the one to use. Use only the Cooper-Robertshaw thermostat. This has been discussed many times in the 335 series engine forum.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #13 (permalink)
Old 04-23-2005, 08:13 AM
ranger429 ranger429 is offline
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
Quote:
starter and fuel pump ,will interchance with302
The fuel pump will interchange with the 351W not the 351M/ 400 motor, and I think the 302-351W, 351M/400 take different starter's.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
  #14 (permalink)
Old 04-23-2005, 06:38 PM
79 f36 79 f36 is offline
79 f36 is starting off with a positive reputation.
body
A 76 2wd long wheel base, 133 inches, cab and bed will fit with no problems to a 79 f 350 4wd, all the holes are the same, and you'll keep the rear gas tank like in the 79. you will just need to cut the hole for the manual transmission thats all ready marked from the factory and will take like 15 minutes to cut and drill and install the 4x4 tranny hump.
also u will need to replace the steering column and the pedals assembly if you are going from an auto to a manual like i did.
the electrical system is compatible with them, I reused all the 76 250 2wd 460/c6 wires
in the 79 350 4wd 400/t 18-205,
the sliding spare wheel carrier in the 2wd is a bolt on on a 79 78, 4x4 the holes are pre drilled,
hi boy front springs will bolt on a low boy giving the truck the same stance, using the rear block will make the 78 79 as tall as a hi boy.
  #15 (permalink)
Old 04-24-2005, 02:04 PM
[quote=ranger429]The fuel pump will interchange with the 351W not the 351M/ 400 motor, and I think the 302-351W, 351M/400 take different starter's.
I'm using a starter from a 351M on my 302 right now everyday, and the 351W is just a taller 302 so starter will fit on there too
__________________
Be Careful
author unknown
Tags
1978 , 1979 , 73 , cable , f100 , floorboards , ford , lectrolite , repairing , replace , rusted , speedometer , tricks , truck , trufit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
