where is best place to buy in b.c. Canada
I have a 2004 f150 lariette and would like to install a 2.5" level kit can anyone tell me where i can get this in the vancouver area. Also i see two different styles one is a daystar which requires a spring compressor spacer goes in between coil and top of strut the other bolts right on top of strut and and then the whole unit mounts to the truck. this type is built by autospring corp. can someone let me know which and where i can get up here
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
