Roller rockers...
Roller rockers...
Anyone using the roller rockers on ford-y-block.com?
If so, are there any mods required for them to fit, or any other tips I can use during install?
Im gonna buy them, a hot cam, headers, and the Blue Thunder Manifold in the next month or so. Should have a pretty hot 292 after all that
The only person I recall offhand using them was Ted Eaton, I believe on a customer's engine. John F. may be using them on his "Hoosier Hurricane" & Jerry Christenson might on his "Blackbird", but Idon't know for certain. All three of these gents can be found on http://www.y-blocksforever.com/index.html under the forum, in the technical section. I'm guessing that somebody there has used them, if not those three. I seem to recall Ted saying they were quality pieces; I think they are made by Dove Engineering, the same guys that were the first to cast up aftermarket FE heads, years before Edelbrock, Shelby, etc. Good luck!
Rocker Arm Specialists also has the aluminum roller rockers, at www.rockerarms.com . They are available in 1.5 and 1.6 ratios.
