Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-09-2005, 08:54 AM
mldmkr1960's Avatar
mldmkr1960 mldmkr1960 is offline
Garage is empty, add now
mldmkr1960 is starting off with a positive reputation.
Question Changing Automatic transmission fluid
I was about to change out my transmission fluid out now that Im at 30,000 and there is a nice drain plug on my transmission pan but I took the rubber plug out to drain the torque converter and cant find one there???? I removed the tin plate and cant find one there either? Is there one, kinda stupid if there isnt, was one on my 97 F150. This one is a 03 F350 with the 4R100.
  #2 (permalink)
Old 04-09-2005, 10:25 AM
Frobozz Frobozz is offline
Frobozz is starting off with a positive reputation.
No more torque converter drain plugs on the newer Superduties, sorry! Either drain and refill what you can (which is not as bad as it sounds if the fluid wasn't burned), or do the "pull the cooler return line and have the trans pump the fluid out for you" full-fluid change trick described around here somewhere or numerous places on the web.
Duncan
__________________
2003 F250 CC
6.0L Bible
  #3 (permalink)
Old 04-09-2005, 11:35 AM
MRBASS's Avatar
MRBASS MRBASS is offline
MRBASS is starting off with a positive reputation.
I have heard this before but My 02 has a drain on the TC, My neighbors 04 f250 also has a drain. Might try rotate the TC around and see if you can find it..
__________________
02 F350 4X4 CC LB
7.3PSD 3.73LS AUTO
AIS,HPX,PRE PUMP MOD
X MONITOR GAUGES
LEVEL KIT & 285'S
5" STOVE PIPE
http://www.ford-trucks.com/user_gall...127190.520.390
  #4 (permalink)
Old 04-09-2005, 02:18 PM
mldmkr1960's Avatar
Transmission fluid
No I went around it twice, what a pain in the a$$. Im doing it in the driveway, had turn it, roll around and check it, turn it, roll around and check it. I changed the fluid in the pan that was it for today. I will either try the other method of the return line or will just change the five quarts in the pan every time I change the oil. I can buy the Motorcraft Mercon at the dealer for $1.95 a quart so the price of it doesnt bother me.
  #5 (permalink)
Old 04-09-2005, 05:33 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
http://www.ford-trucks.com/article/i...nsmission.html
Very usefull article written by Racerguy!
__________________
'12 F250 Superduty CC 4x4 6.7L PSD
  #6 (permalink)
Old 04-10-2005, 05:48 AM
Lnd Svyr's Avatar
Lnd Svyr Lnd Svyr is offline
Lnd Svyr is starting off with a positive reputation.
Are you sure the dealer quoted the correct fluid. I called a couple dealers around my parts and they both said $4.60 a quart for Mercon SP and it has to be SP. Also, from reading about the drain and fill hereon, I believe it takes almost 10 quarts and a new external filter (dealers wanted $53.00 for the filter--got a Wix from filter1.com for $12.00 with shipping).
  #7 (permalink)
Old 04-10-2005, 07:41 AM
mldmkr1960's Avatar
Mercon fluid
There are three mercon fluids, Mercon, Mercon V, and a Mercon Synthetic. The one I bought was the Mercon that was what was listed for my truck regular Mercon, as what it said on the end of my dipstick. I didnt change the filter just pulled the drain plug on the pan and all I got out was about five quarts.
  #8 (permalink)
Old 04-10-2005, 07:56 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
The article says it was written by Mark Kovalsky. Is that Racerguy?
I've used it several times. It works great!
  #9 (permalink)
Old 04-10-2005, 10:46 AM
Quote:
Assuming "Mercon synthetic" is Mercon SP, then that is my understanding of the 3 fluids. Mercon goes in the E4OD and the 4R100 (like you said you have), while Mercon SP goes in the Torqshift. I don't know what Mercon V goes in, but it isn't a Superduty!
Duncan
__________________
2003 F250 CC
6.0L Bible
  #10 (permalink)
Old 04-10-2005, 11:20 AM
snakebit snakebit is offline
snakebit is starting off with a positive reputation.
"I believe it takes almost 10 quarts and a new external filter"
Is there a external filter also? I changed the filter in the pan, I thought that was it.
__________________
08 F250 V10 6spd CC FX4 4x4: company truck.
06 TJ Rubicon 4.5" lift, 35" BFG M/T's and stuff...
03 F250 V10 Auto CC 4x4: 8" Superlift all spring, 38" Toyo M/T's, 16x10 Stonecrushers, Delta chip, FIPK, Exhaust, and more...
04 Denali XL, mama's bus (waiting for the right Expedition Limited EL to come along).
  #11 (permalink)
Old 04-10-2005, 12:29 PM
mldmkr1960's Avatar
Filter
Yes the Torqueshift takes the SP fluid and has the external filter the one I have does not. BTW its 5.4, 350, 03 not a diesel.
  #12 (permalink)
Old 04-10-2005, 02:55 PM
tvsjr tvsjr is offline
tvsjr has a good reputation on FTE.tvsjr has a good reputation on FTE.tvsjr has a good reputation on FTE.
Quote:
Duncan
4R70W and I believe the 5R55E. Lighter-duty transmissions put behind the 4.6L V8 in the F150, Expedition, Mustang, etc.
  #13 (permalink)
Old 04-10-2005, 08:02 PM
So is there an external filter on a 4R100? 03 CC 4x4 V10.
__________________
  #14 (permalink)
Old 04-11-2005, 07:44 AM
The 4r100 does not have an external filter from the factory.
Tags
2003, bad, change, changing, duty, effects, expedition, f150, f250, fluid, ford, oil, put, super, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
