Synthetic Transmission Fluid and E4OD - Ford Truck Enthusiasts Forums
Old 04-08-2005, 07:57 PM
SmittyD SmittyD is offline
SmittyD is starting off with a positive reputation.
My mechanic told me not to use synthetic transmission fluid in my F150, 300 six with an E4OD transmission because he is of the opinion that it will damage it.
Does anyone know why I can't use synthetic in the transmission?
I would also like to change the differential oil and replace it with synthetic. Is there a way to drain the differential oil other than removing the rear cover?
Thanks,
Smittyd
Old 04-08-2005, 08:23 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
I've been told this buy a couple of tranny builders, but not because it will damage it. But because it is a waste of money, unless your trans temps are higher than normal.
Not sure about the rear, if it's an 8.8, then I doubt it.
Old 04-08-2005, 08:26 PM
tex94F250's Avatar
tex94F250 tex94F250 is offline
tex94F250 is starting off with a positive reputation.
I don't have any good reason. I do have an E4od with 246,000 miles on it and all I use is the factory reccommended transmission fluid and Lucas transmission treatement everytime I have it flushed and change the filter. It averages about every 8 months or so. I have maintained it like that since new and have no problems, knock wood. The E4od is a good transmission when you have the '94 or later with all the mods to make it last. It is expensive to rebuild and I'm just not gonna go synthetic. Your tranny, your choice, I just wouldn't tempt fate.
Old 04-09-2005, 07:54 AM
Thanks for the good replies. From what I am hearing I will stay with the conventional fluid.
Thanks,
Smitty
Switching to Full Synthetic - 1996 E4OD CircleRat Clutch, Transmission, Differential, Axle & Transfer Case 8 01-03-2014 11:07 AM
Synthetic Trans Fluid? danlee Clutch, Transmission, Differential, Axle & Transfer Case 19 10-17-2013 03:41 PM
Swapping differentials, t-case and power steering fluids to synthetic 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 5 05-06-2013 12:42 PM
DIY Oil Change and Transfer case; what about E4OD christcorp 1987 - 1996 F150 & Larger F-Series Trucks 7 04-01-2007 08:37 PM
Synthetic Oil in Limited Slip Diff laka Oil & Lubrication 9 06-02-2001 09:16 PM
Tags
02, anti, damage, e40d, e4od, f150, flued, fluid, ford, lucas, oil, slip, synthetic, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
