Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-08-2005, 03:24 PM
Babin Babin is offline
Garage is empty, add now
Babin is starting off with a positive reputation.
Exclamation Fuel pressure Issue?
1987 302 EFI
Ok ok, I really need help here. My van as to run in 2 weeks.
Here's the other topic explaining my problems so far:
http://www.ford-trucks.com/forums/showthread.php?t=3152...ad.php?t=315230 (posted in november)
What I did today: removed the doghouse to acess the fuel rail.
Key ON: fuel bursting out of the fuel pressure check valve then stops. I gess the electric pump builds up the pressure to start. I also gess that when you crank and start, it runs constantly.
Key ON once, doesn't start (but crank all right). Key ON, OFF, ON, cranks almost starts, burns something. When I go ON three times, it starts for about 2 sec and dies. Same scenario on both thanks.
I crawled under it. My friend was operating the key. Key ON on front tank: bzzz and click in the front tank. Switch to rear, key ON on rear tank, bzzz and click.
It doesn't run on either tanks. Looks like I need to build some pressure to get it to run.
My gess:
- Electric pump weak close to death
or
- Tank switch box improperly working.
I still need to find a fuel pressure gage.
Is the electric pump working constantly when you crank the engine?
Thanks for your help.
Etienne
  #2 (permalink)
Old 04-11-2005, 09:26 AM
ranchero77's Avatar
ranchero77 ranchero77 is offline
ranchero77 is starting off with a positive reputation.
or it could just be a bad pressure regulator. that could explain your "When I go ON three times, it starts for about 2 sec and dies" cycling the pump multiple times on may be building enough pressure to make it past the faulty regulator. or the same reason for suspecting a weak pump. but still no use in stabbing at faulty parts till you put a gauge on it.
  #3 (permalink)
Old 04-19-2005, 08:39 PM
Had it towed to the garage because the weather was bad and I was in a rush.
Faulty MAP sensor was the problem...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
