Energy Suspension Front Axle Pivot Bushing?
When I installed my Polyurethane front axle pivot bushings from Energy Suspension, they came with 2 1/8th inch thick Polyurethane rings (might be spacers ?) the same size as the bushings.
Didn't seam to fit anywhere.
No instructions, Where do the poly rings go?
Anybody know?
The Axle pivot bushings for Most Ford TTB and I- Beams are the same.
My lift kit is on the way and if they serve a pupose I want to use them .
Anybody know?
These rings are called thrust washers. They are used if you use the shell that they supplied rather than re-using your existing shell. The bushing goes between the pivot arm and the mounting bracket on the shell side opposite the shell flange with tapered edge away from the pivot arm. I think they do this since the new shell does not get crimped like the old shell and the thrust washer keeps the shell from possibly pushing out. I had to call Energy Suspension to get this information (instruction sheet #1705). As I recall the washers are approx 2 1/8" diameter and approx. 1/4" thick.
anthonym92
01-11-2024 07:25 PM
granny_rocket
04-23-2017 12:26 PM
70-360fe
09-30-2013 02:09 PM
WHITE F150 ROB
03-09-2011 09:55 PM
