TCC solenoid location
«2000 Ranger Table of Contents»
«Group 3: Powertrain»
«Section 307-01A: AUTOMATIC TRANSMISSION — 4R44E»
«IN-VEHICLE REPAIR»
Solenoids — Shift, Torque Converter Clutch, Electronic Pressure Control
Removal
1. Disconnect the battery ground cable. For additional information, refer to «Section 414-01».
2. Raise and support the vehicle. For additional information, refer to «Section 100-02».
3. Drain the transmission fluid. For additional information, refer to «Fluid Pan, Gasket and Filter» in this section.
µ 4. Remove the transmission fluid filter.
1 Remove the transmission fluid filter screw.
2 Remove the transmission fluid filter.
µ 5. Note:
Main control assembly does not need to be removed for solenoid service.
Remove wire loom guide and protector.
l Carefully lift up on wire loom guide and protector and disengage the retaining pins from the solenoid clamps.
µ 6. Disconnect the appropriate solenoid electrical connector.
1 Disconnect shift solenoids electrical connectors.
2 Disconnect the torque converter clutch (TCC) solenoid electrical connector.
3 Disconnect the electronic pressure control (EPC) solenoid electrical connector.
µ 7. CAUTION:
The TCC solenoid and converter modulator valve may pop out of its bore. This may damage the solenoid or converter modulator valve.
CAUTION:
Shift solenoid (SSC) may pop out of its bore. This may damage the solenoid.
Remove the shift solenoids.
1 Remove the wire harness.
2 Remove the solenoid clamp screws.
3 Remove the solenoid clamp.
4 Remove the appropriate solenoid(s).
Installation
µ 1. Install the new solenoid(s).
µ 2. CAUTION:
The solenoid clamp must be installed in the TCC and EPC solenoid grooves, shift solenoid pockets and the No. 204 plug.
Install the solenoid clamp.
1 Position the solenoid clamp on the main control valve body.
2 Install the solenoid clamp screws.
µ 3. Connect the six solenoid electrical connectors.
1 Connect shift solenoid SSA, SSB, SSC, CCS electrical connectors.
2 Connect the torque converter clutch (TCC) solenoid electrical connector.
3 Connect the electrical pressure control (EPC) solenoid electrical connector.
µ 4. CAUTION:
Excessive pressure may break the retaining pins.
Install the main control valve body wire loom.
l Align the retaining pins to the holes in the solenoid clamps and gently press in the main control valve body wire loom guide and protector.
µ 5. Install the transmission fluid filter.
1 Install the transmission fluid filter.
2 Install the transmission fluid filter screw.
µ 6. Install the transmission fluid pan.
1 Position a new transmission fluid pan gasket on the transmission fluid pan.
2 Align and install the transmission fluid pan.
l Loosely install the transmission fluid pan screws.
µ 7. Tighten the transmission fluid pan screws.
8. Lower the vehicle.
9. Connect the battery ground cable.
10. Fill the transmission to the proper fluid level and check for proper transmission operation.
l Use MERCON® V; Automatic Transmission Fluid XT-5-QM meeting Ford specification MERCON® V;.
«IN-VEHICLE REPAIR»
Removal
µ 5. Note:
µ 7. CAUTION:
CAUTION:
Installation
µ 2. CAUTION:
µ 4. CAUTION:
Opps, I assumed and you know what that means....LOL, here you go....
«Section 307-01B: AUTOMATIC TRANSMISSION — 5R55E»
«IN-VEHICLE REPAIR»
Removal
1. Disconnect the battery ground cable. For additional information; refer to «Section 414-01».
µ 3. Note:
Transmission servo heat shield needs to be unclipped from the fluid pan rail and positioned out of the way for fluid pan removal.
Loosen the nut and position the heat shield out of the way.
4. Place a drain pan under the transmission fluid pan.
5. Drain the transmission fluid. For additional information, refer to «Fluid Pan, Gasket and Filter» in this section.
µ 6. Remove the transmission fluid filter.
µ 7. Note:
µ 8. Disconnect the appropriate solenoid electrical connector.
µ 9. CAUTION:
CAUTION:
Installation
µ 2. CAUTION:
1 Connect shift solenoid SSA, SSB, SSC, SSD electrical connectors.
µ 4. CAUTION:
µ 8. Position the servo heat shield over the servos and clip it to the pan rail.
9. Lower the vehicle.
10. Connect the battery ground cable.
11. Fill the transmission to the proper fluid level and check for proper transmission operation.
l Use MERCON ® V Automatic Transmission Fluid XT-5-QM or equivalent meeting MERCON ® V specification.
«IN-VEHICLE REPAIR»
Removal
µ 3. Note:
µ 7. Note:
µ 9. CAUTION:
CAUTION:
Installation
µ 2. CAUTION:
µ 4. CAUTION:
No gear change after installation new solenoids
Vehicle: 1997 Ford Ranger 2.3L, 4R44E automatic transmission.
Problem: Car is idling in park, I put into any gear nothing happens.
Process of Work Performed: Turned car off (battery still connected), Dropped transmission fluid pan, changed filter and installed new (refurbished) solenoids - 4 x shift solenoids, 1 x TCC solenoid and 1 x EPC solenoid, replaced pan with new gasket, torqued everything to spec, refilled transmission fluid with Mercon V (4-quarts), idled for 10 minutes, checked fluid level, shifted all gears with foot on the brake, re-checked fluid level, tried for a test ride. no movement in drive, reverse or lower gears (i.e., 3, 2). No change in sounds or anything. Car does not stall.
Internal diagnosis and questions: When I changed the solenoids I did my best to keep trans fluid from dripping on the solenoid harness contacts that plug into the actual solenoid valve, but chances are a few drops may have touched the connectors. I made sure all rubber o-ring gaskets came out with old solenoids and new gaskets were on the replacement solenoids. Based on the truck not responding to any change in gear I want to believe this is an electrical issue. I checked a few fuses (i.e., 13 and 16) and they were fine. The truck never jerked when I changed gears or made any odd noises. Just completely unresponsive to changing gears.
Thanks for your help!
[QUOTE=jthrash85;19926626]Vehicle: 1997 Ford Ranger 2.3L, 4R44E automatic transmission.
@Ken00 Followed your procedure but now I have a new problem....
Thanks, @Ken00 for responding. For anyone else who read my post I am chasing it down on another thread with some of the community here:
https://www.ford-trucks.com/forums/1...l#post19926637
hollenjoe
04-27-2012 09:49 PM
biglewfish
08-12-2005 01:07 PM
Allen90aerostar
08-07-2003 08:39 PM
