How to replace the ball joints on your 97-03 F-150 4X4 - Page 12 - Ford Truck Enthusiasts Forums
  #166
Old 08-19-2009, 06:23 PM
dozer dozer is offline
dozer is starting off with a positive reputation.
Thanks for the great info Racerguy. I have a 2001 4.6L 4x4 with 124k miles. I am having a similiar problem to that of Syracuse from 09-28-2005, 01:02 AM on page 3. I get a pop when turning only to the right at slow speeds. Do you think this could be the Pitman Arm as well? I replaced my lower and upper ball joints, and I took it to a mechanic that said he couldn't see anything wrong with it. It does not happen everytime and it is hard to listen to because it only happens when the truck is in motion. The mechanic said it might be a body mount. Is there anyway to tell if it is a body mount? I don't know why it only happens when turning to the right.
  #167
Old 08-19-2009, 08:18 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
it may be a cv joint.
  #168
Old 08-20-2009, 02:49 PM
Thanks Papa. I'll give it a shot...
  #169
Old 08-25-2009, 07:20 PM
mwegner1 mwegner1 is offline
mwegner1 is starting off with a positive reputation.
I just wanted to thank Racerguy and everyone else that has contributed to this thread. I am a novice garage mechanic at best, but I was successfully able to replace my upper ball joints (and arms),lower ball joints, tie rod ends, and 4 shocks based off of what I learned here. I basically setup the laptop in the garage and followed Raceguy's instructions step by step for the ball joints. The alignment guy at Firestone said the job I did looked just fine. Like others have said, the Autozone press doesn't get it done by itself. I started the lowers by beating on them, then was able to press them out. As for pressing the new lowers back in, I had to use a 1 inch wrench laid across the spacer to torque the press onto, as the adaptor in the kit was too tall, and there wasn't room for it to fit in there with the new ball joint. Other then that, no major problems. Just too me a long time, but hey, I'm new at this.
  #170
Old 08-29-2009, 05:24 PM
stang3O2 stang3O2 is offline
stang3O2 is starting off with a positive reputation.
I also wanted to thank Racerguy and everyone that contributed to this thread. Personally had never done ball joints myself, but was able to install upper a-arms, lower joints, all tie rods, idler arm, and 4 new shocks. My buddy had the ball joint press, and together we were able to complete this whole project in 3.5hrs, which I thought was great. I have an 02 F-150, 120K miles on original parts. The truck has had 35" tires and a 3" body lift for the past 50K. Everything came apart great. One thing I did that I think helped a bit, I sprayed PB Blaster on all nuts, bolts etc for 5 days straight. Thanks again for a great thread!!!
  #171
Old 09-03-2009, 08:30 AM
aedsall78 aedsall78 is offline
aedsall78 is starting off with a positive reputation.
Thanks
Racerguy,
Replaced upper and lower on my 99 expedition yesterday, thanks very much for the instructions, took 2.5 hours with no holdups except that the press that I rented from Autozone needed a "ford adapter" and I had to improvise a bit to avoid making a trip back to the store.
Thanks again!
  #172
Old 09-20-2009, 03:18 PM
montanafordman's Avatar
montanafordman montanafordman is offline
montanafordman is starting off with a positive reputation.
I'll echo the many thanks for this post Racerguy! I had a shop do my lower ball joints about 3 years ago - and they didn't grease them when they were installed so one road trip accross the country towing a trailer and they were shot already within the first 5K miles - so for the last three years they were so siezed up they wouldn't take much grease, which would quiet the squeaks for a short time, and lately it would take NO grease and it was downright embarrasing to drive my truck through the nieghborhood - especially at the weird hours I work with a truck you can hear coming a block away! Of course with the lowers worn out I figured everything else was wearing twice as fast so I finnally did the uppers, lowers, inner and outer tie rods, all four shocks with my dad over labor day weekend and MAN what a difference!! I missed how nice it was to drive a quiet truck! It was SCARY how much play was in the drivers side lower ball joint! and they were put in only 40K ago! After that was done I could hear my rear end squeaking when I was backing up so I also replaced my U-joints which solved that issue as well. My shocks were original at 150K so needless to say they were past due! When I compressed them by hand and pulled them out of the shock towers they stayed compressed for a minute or two until they S L OW LY exteded again! My pickup drives like a brand new truck now let alone its SILENT! I saved about 1500 in labor costs! I also have the satisfaction knowing the job was done RIGHT and that I installed high end MOOG parts and most importantly GREASED THEM! Kudos for the great post - except I hate you all who did it in 2.5 hours! A little learning curve for me, some frustration but it worked out - and if anyone else is on the fence about this - go for it!
-Montanafordman
  #173
Old 09-20-2009, 07:46 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Quote:
-Montanafordman
Thanks for the encouragement, montana - I think I'll try it all soon.
  #174
Old 10-06-2009, 05:30 PM
smoke14's Avatar
smoke14 smoke14 is offline
smoke14 is starting off with a positive reputation.
Ball Joints
Racerguy you look to be da man on this ball joint thing. I have a question I printed your whole thread for the ball joint replacement and I'm not sure if I missed anything but I have a 2000 f150 4x4 5 lug and I am only changing the lower ball joints both sides. 1st question do I need an alignment after replacing lowers only? 2nd do you think I can get away with a large heavy duty c-clamp and the right size either pipe nipple or socket for removal and reinstall? I am very mechanically inclined and have done ball joints before mostly rivited on ones and I realize the value of not damaging the new joint. for havinf 176k my truck is in very good condition underneith no rust.also do you also do engine work at your work maybe I can pick your brain on some engine gremlins I have been having. thanks' in advance
  #175
Old 10-06-2009, 08:23 PM
Drumrkane Drumrkane is offline
Drumrkane is starting off with a positive reputation.
Quote:
I just did this job on my expy last month and the only problem I see with replacing lowers only is that you do have to remove the steering nuckle, (can't get lowers out without doing this) which means you have to seperate the upper ball joint from the nuckle. This is usually difficult to do without causing damage to either the boot or joint. Sometimes the CV shaft comes out hard, sometimes not...mine both came out easy.
Maybe Racerguy can comment on using a clamp and nipples...I've never tried it.
You should have the truck aligned after this job.
  #176
Old 10-06-2009, 08:24 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
If you're only replacing the lower ball joints you don't need to do an alignment although it never hurts to have it checked after any front end work.
The ball joints will probably fit too tight for a C-clamp to work but some people can make pretty much anything work
If you want to start a new thread about your engine problems it's pretty likely that someone here will be able to help.
  #177
Old 10-22-2009, 12:57 PM
smoke14's Avatar
Thanks' to your detailed post I was able to do the lowers on my 2000 f150 4x4 in 2 1/2 hours with no problems. and with no rented tools. and someone suggested freezing before job cant be sure how much it helped but they were not that difficult to reinstall with the help of a floor jack onder control arm with a 2" dia. 4" long pipe nipple. and a bfs on top to pound down from top of ca to press onto joint. thanks' again.
  #178
Old 12-31-2009, 02:23 PM
paul's old fords paul's old fords is offline
paul's old fords is starting off with a positive reputation.
Thanks
Thank you for a very informative post. It was most helpful. Hope I can return the favor some day.
  #179
Old 03-16-2010, 07:25 PM
jessemedley jessemedley is offline
jessemedley is starting off with a positive reputation.
I just did a lower ball joint on my truck thanks to the write up.
I purchased a premium lower ball joint from NAPA.
the boot wasn't attached to the ball joint and i couldn't figure out how to securely attach it.
I'm worried that this could lead to problems.
should the boot somehow have been attached.
or is there a way i can secure it more?
Thanks for all the info and pictures.
  #180
Old 03-16-2010, 08:21 PM
Racerguy's Avatar
Welcome to the forum jessmedley
Usually the boot just pushes down over the ball joint without anything holding it on. It should fit pretty tight around the body of the joint.
Sometimes even after the ball joint is installed you can push the boot down further to make sure it's seated.
How to replace your V-6 Escape's spark plugs Racerguy Escape & Escape Hybrid 69 12-19-2016 03:04 PM
How to replace your 4.6L & 5.4L spark plugs Racerguy 1997 - 2003 F150 653 11-05-2016 11:44 PM
BALL JOINTS - My turn - HELPFUL HINTS/LINKS 71-4R3SONS Excursion - King of SUVs 35 08-11-2014 11:25 AM
2WD Lower Ball Joint Replacement Flaw 1997 - 2003 F150 15 01-11-2006 10:03 PM
Bronco concept Racerguy General NON-Automotive Conversation 25 01-05-2004 08:27 PM
Tags
1997, 1999, 4x4, 97, ball, change, explorer, f150, ford, joint, joints, lower, removal, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
