Did the door chime mod, so now the dome&cargo light...
I like now that I can have the doors open (thanks to Kwiks easy intructions) with the key in the ignition, but the cargo and both dome lights stay on. It would be great if I could use a switch to turn off all the lights also. Any ideas? And as always, thank you in advance.
You don't have the dimmer switch rolled all the way to bright do you? That's how my dome light turns on with the doors closed.
On my 2002, under the plastic passenger kick panel, there is a black wire with a light blue tracer which controls the dome/cargo light circuit. Cut a switch into this wire - dome light killed at will - Key in, radio on, doors open, no dome light.
I put a rocker switch (almost any "automotive" 12v SPST) I bought at Autozone near the light switch, and ran some wire (14 ga) from the switch to where I cut the wire. You can put it pretty much where you want.
