302 bored 30 over? 60 over? - Ford Truck Enthusiasts Forums
Old 04-06-2005, 11:46 PM
F-150Guy F-150Guy is offline
F-150Guy is starting off with a positive reputation.
i just tore down my 302..and the pistons are stamped 30....what would this make my 302 in cubic inches? how about 60 over? does this make any noticable difference in power/mpg? thanks.
Old 04-07-2005, 09:50 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
just boring wont give to much in gains if any. it can cause overheating if the cylinder walls are to thin. i believe a 302 with a .30 or .40 bore is a 306 but not 100% on that. I wouldnt take a 302 over .40 personally unless it was an older 70's block
Old 04-07-2005, 11:45 PM
yea, didnt think so...im not sure i have to bore it out yet, i wont if i dont have too
Old 04-08-2005, 01:49 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
if you have to I would try, and get a core block from the junk yard that hasn't been bored yet if it was me. 40 is the max I would consider on a 302 block without sonic testing and even then I would really look into a new block it's not like they are rare or anything like that.
Truck 302 to Mustang 302 H.O injector ?'s makingaZJ 1987 - 1996 F150 & Larger F-Series Trucks 13 02-19-2013 11:33 AM
302/460 swap jdgreen72 1967 - 1972 F-100 & Larger F-Series Trucks 5 05-12-2007 01:30 PM
302 bored .30 over? F-150Guy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 03-21-2005 03:36 PM
Best 302 Cam AceTrucking Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 04-09-2004 06:35 PM
302 into a stroker mdh627 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 17 08-27-2003 08:50 AM
Tags
1977, 30, 302, 40, 50, 60, bored, cu, cubic, ford, inch, makes, overheat, specs, what
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
