Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-05-2005, 09:16 PM
1994_ranger 1994_ranger is offline
Garage is empty, add now
1994_ranger is starting off with a positive reputation.
having a problem!!!
Alright i own a 2.3L 94 ranger with about 170,000 miles on it. Lately it has been idleing rough. It only does this about 3 times in a day out of starting it maybe 7 times i will start it and it will be real rough then stall. I would then start it back up and play with the gas pedal, it normally idles about 500 and i have to get it at about 1,500-2,000 rpm's and hold it there for a second or two. I checked my oil it was about a quart low so i put a quart of oil in there. I recently put in a new air filter, i cleaned out the throttle body. I am clueless what it could be. After i let it idle high it idles normally and it runs great. My guess is maybe a new fuel filter, maybe i have bad gas. I am clueless help me out please
  #2 (permalink)
Old 04-06-2005, 08:33 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE !
If you think the fuel filter is old, change it. They're not expensive.
Is the check engine light on? If so, you'll have to pull the codes.
This link is to the "READ FIRST-Technical information" thread on the FTE Ranger board...
http://www.ford-trucks.com/forums/sh...d.php?t=107538
Do one repair/service at a time & note any changes in how your truck runs.
The guys on the Ranger board can help you through pretty much any problem/repair/service you need to do.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #3 (permalink)
Old 04-08-2005, 04:45 PM
Hardwareman Hardwareman is offline
Hardwareman is starting off with a positive reputation.
Smile
Try changing out you're IAC valve. If you've already done the basic tune up on it already though.
All the symptoms you're describing are consistent with that of a IAC valve going bad. The IAC will also be intermittent and not always appear to be bad. It will also not throw a CEL.
It did'nt in my case anyway.
Later, Allen
__________________
95 Ford Ranger XLT
2.3L w/K&N intake
6" lift w/31"'s
4.56 gear ratio
http://members.cardomain.com/ulcerman
  #4 (permalink)
Old 04-08-2005, 06:25 PM
Well i talked to my auto teacher and he did tell me it was the IAC valve so i took that out i cleaned it out with carb. cleaner really good, i even went back and sprayed the trottle body out and cleaned that out and it did work. But the only thing is i have noticed it improving the idle but it did the same thing again, so is it going bad or are there other things. Im gonna do a tune up sometime this weekend so hopefully that will help.
  #5 (permalink)
Old 04-09-2005, 12:48 AM
Quote:
Yes, that tells me that it is definitely going bad. They sometimes will not go completely bad but do what your describing, and then sometimes work right.
Wierd if you ask me.
But you're going to need to do a tuneup if you have'nt already done so.
Cleaning it alone is not enough, it needs replacement. For some reason the IAC will not last long after a cleaning.
P.S. Try " THE RANGER STATION " forums. They are awesome!!
__________________
95 Ford Ranger XLT
2.3L w/K&N intake
6" lift w/31"'s
4.56 gear ratio
  #6 (permalink)
Old 05-13-2005, 10:13 AM
jinx102672 jinx102672 is offline
jinx102672 is starting off with a positive reputation.
Before replacing the IAC valve, get the codes pulled to see if there are any other problems.
I was in the same situation as yourself not to long ago and this is what I found to be my problems:
Faulty EGR valve position sensor (clogged)
Faulty EGR valve solenoid (clogged/mechanical malfunction...it did not throw a code because the solenoid portion of it was still functioning properly.)
Faulty Throttle position sensor (150,000 mile wear-out)
I never had to replace the IAC valve. Yes, in a lot of cases it is the problem part, but it is also one of the more expensive parts.
Good Luck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
