4-speed Tranny Question...
Old 04-13-2005, 12:14 AM
Boyd's Avatar
Boyd
Boyd is offline
You will probably at least need to modify the driveshaft as the output shaft is most likely different than your T18. I have thought of getting one of these newer 5 speeds for my 85 Crew Cab dually 2wd with a small block engine.
Old 04-13-2005, 02:10 PM
85F_150driver's Avatar
85F_150driver
85F_150driver is offline
there was a fella who changed his c-6 for a zf in his truck it was about 4 months ago he did a thread on it and said everything he needed and everything he had to modify/change. You might be able to search for it and find it.
Old 04-13-2005, 02:52 PM
savage066's Avatar
savage066
savage066 is offline
your '86 has a hydraulic clutch, but it's an external slave cylinder. it only works the clutch fork. the ZF will require a concentric slave cylinder, which fits inside the clutch assembly. any ford 5-speed is like this. the only bolt-in replacement for the t-18 is a t-19 or NP435, both of which have a granny first and no OD, or the TOD/SROD tremec T170, which are both 4-speeds, with 4th being OD. anything else is going to need a clutch hydraulic system modification.
Old 04-13-2005, 02:58 PM
savage066's Avatar
savage066
btw, the TOD and SROD aren't too hard to find...just look for a junkyard 80-86 F100-250...look for an aluminum case (i.e. not rusty). generally these are found in 300 six trucks, some 302s.
Old 04-13-2005, 04:02 PM
drumlinecowboy's Avatar
drumlinecowboy
drumlinecowboy is offline
savage, is the TOD a direct swap also? i need gas mileage bad, as im gettin maybe 14 highway. 20 would be a lifesaver. i dont want to do too much work either. just wanna take her out and put er in with maybe a new clutch.
Old 04-13-2005, 04:16 PM
savage066's Avatar
savage066
yeah, a TOD is a direct bolt-in for all 300s up to '86. '87 and up will need a bellhousing from an '86 or earlier. i prefer the TOD to the SROD because it's a top-mounted shifter, so shifts are more precise. other than that, they are the same. the casting code is RTS on the TOD, and RUG on the SROD. you might also find them referred to as the Tremec T170FT (TOD) and T170FS (SROD). hope that helps!
Old 04-13-2005, 05:44 PM
fordfan302's Avatar
fordfan302
fordfan302 is offline
well i guess the TOD or the SROD is the right tranny for me...all i really need is a overdrive, so thats what im gonna go with
Old 04-13-2005, 09:34 PM
drumlinecowboy
thanks man... im gonna price rebuilds round here and and see what All Truck Nats has
Old 03-08-2012, 05:50 AM
goodold85fordf250's Avatar
goodold85fordf250
goodold85fordf250 is offline
4speed tranny problems
i was wondering what the problem could be i have a 85 ford f250 4 speed 4x4 and it will move with all the gears but it makes a really bad wine noise and you can feel it i was wondering if that could just be low in gear oil or what could be the problem and it does have the 460 carb
Old 03-08-2012, 10:40 AM
1983F1503004x4's Avatar
1983F1503004x4
1983F1503004x4 is offline
You just registered to bring back a seven year old thread...
It would help a little if you could start a new thread so people could keep track of what topic your talking about.
If you think it's low on gear oil, then check.
Old 03-08-2012, 12:43 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
It's normal for the heavier 4-speed transmissions (T18, T19, NP435 etc) to make some whine in 1st, 2nd, 3rd, & reverse; 4th should be silent.
But if the noise is excessive, or you can physically feel the trans grinding over, something more serious is wrong.
I would check the oil anyway. There are two plugs on the side of the transmission - the upper one is the oil level.
HotLead
02-12-2015 05:03 PM
zachsmith
1978 - 1996 Big Bronco
01-21-2012 10:33 PM
FordBronco4life94
45
01-23-2011 01:32 PM
alwaysmessedup
05-21-2003 01:55 PM
GregCS
03-05-2000 12:21 PM
Quick Reply: 4-speed Tranny Question...
