Installation step to install F250 heater core - Ford Truck Enthusiasts Forums
Old 01-13-2001, 10:22 AM
runner runner is offline
runner is starting off with a positive reputation.
Recently, I posted the message below....
It was found that I needed a new heater core so I bought a one and I'm ready to Install. Can anyone give me a step by step installation or guide me to a place where I can get this information to install this in my F250 88?
many thanks...
Runner
F250 88
When I run my heater in my 88 F250 it smells like anti freeze. Also the windshield fogs up. I was told by a freind that I might have to replace my heater core because of a leak or have it repaired.
Anyone out there have any advice on what would be the best way to resolve this problem. I want to repair this myself. Any advice would be greatly apprciated.
Many thanks,
Runner
Old 01-13-2001, 11:10 AM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
This is a very,very easy job to do. Start by removing the heater hoses from under the hood (change to new is recommended, so slice the hose at the nipples for easy removal),remove any sealant or foam around the tubes and save aside for later, then from inside, remove glove box (simply release side retainer/stop and unhinge from main dash), next remove the h-core cover plate (a rectangular cover with about 4-6 screws visible thru glovebox hole). Now you will see the heater core first hand, which is easily pulled out of the cavity at this time, but, you will have to snake it out between the dash and the cavity after you pull it all the way out. No big deal to scratch up the old one doing this, but not good for the new one.At this time, clean the inside of the cavity with a good degreaser to remove coolant residue. Before you install the new one, you can gain more room by trimming back the 2 bottom locator tabs that help steady the h-core cover, they are about 3/4' long now, trim down to 3/8" or so, this will make snaking the new one in a lot easier.Once the new one is in, you should install the hoses at the core at this time, being pretty easy on the new core. If the core keeps sliding back under force, have a helper hold it steady from the inside while you push the hose further onto the nipples.When you have the hoses on and the core is as far forward as it can go, reinstall the inside cover and glove box, the tighten down the hose clamps. Before you start the engine, add any missing coolant to the radiator and overflow jug, and replace caps. Start the engine to check for leaks, if none seen , allow the engine to warm up 100% , then check for hot air available in all functions of the heater control. A note, I have had some trucks seep a little coolant out of the heater core cavity for a day or so after, don't worry , it is just old coolant that has accumalated in the box and should dry up after a day or so.Stop the truck and allow to cool off, then carefully remove the rad. cap to refill if necessary as well as the recovery jug.
Phil
Old 01-13-2001, 07:28 PM
gary_p gary_p is offline
gary_p is starting off with a positive reputation.
Heater hoses Blanketr Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 02-05-2016 06:20 PM
Heater hoses F-250 w/7.3 Blanketr 1987 - 1996 F150 & Larger F-Series Trucks 0 02-03-2016 11:21 AM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 08:55 AM
1990 ford f250 heater core replacement vynck143 1987 - 1996 F150 & Larger F-Series Trucks 4 10-05-2011 05:30 PM
Need to bleed the clutch in my 88 F250 runner 1987 - 1996 F150 & Larger F-Series Trucks 1 03-15-2003 10:25 AM
Tags
1999, 2001, 88, box, change, core, f150, f250, ford, fusion, glove, hd, heater, leak, replace, truck, unhinge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
