Harbor freight puller kit
I was going to buy the 46 pc puller kit from harbor freight to pull the harmonic dampner on my 79 f 150 and the steering wheel later. Well i looked at the instructions they have for it @ harbor freight and it does not say whether it can be used to reinstall it. It says how to pull but not how to install. Do i need another special tool to install it and if so where can i find one for cheap? The harbor freight kit is only 10. Part # is 37714-5VGA and is made by pittsburgh i think. Thanks
the HF kit worked on my 302 and 460 without problem
Sam
Puller kit.
I bought that same kit last Saturday and pulled mine with no problem. Installed it back on by just pushing it by hand and tapped it a couple of times with a rubber mallet. It was on far enough for the retaining bolt to reach and just pulled it the rest of the way with the bolt and torqued it to spec. I also have a 302 in a 1995 F150. Good luck.
RickW2007
31
03-05-2017 12:16 PM
3000gtman
13
10-25-2016 08:26 PM
