Ok to install circuit breaker between alternator and battery?
I recently upgraded my G2 to a 200amp G3 alternator. Right now I have it going through the stock fusible link wires, but I want to put in a breaker with 200amp capacity bewteen the alternator and the connection on the solenoid. Will a manual reset breaker be ok or should I look to 200 amp ANL type fuses? Thanks for the input
Originally Posted by WhiteBlazze
ok...so you install the breaker. What are you going to do when your driving and somethin trips the breaker off. You car will stay running for a bit till the battery drained out. How are you gonna prevent that??
Originally Posted by body9599
Well...i suppose that it would be no different then if it burnt through a fuse except i would not have to carry a spare fuse, but...I was thinking of installing a relay across the breaker that would turn on a LED in the cabin should the breaker ever trip.
1950flatbed
19
12-13-2016 12:49 PM
Luke76
04-30-2014 09:53 PM
Visseroth
02-10-2012 09:29 AM
