Mpg Help!!!!!
Mpg Help!!!!!
In light of the rising gas prices, I'm looking for ways to improve my mpg. Right now I get 16.6 mpg with my 04 superscrew 4x4 5.4l. I have some flowmaster duals but everything else is stock. Is a K&N Air Filter worth the money. They say it helps. Does anyone have proof? Any other suggestions would be helpful. Thanks
If you drive a lot of miles, it might pay for itself in a year or so. I put one in when I first got the truck, and then later removed it for service reasons. I forgot to put it back in for weeks, then when I put it in, I forgot I had done it. (When you're over 50, this is normal..) I was surprised at a sudden small (under 1 mpg) improvment. It wasn't till I remember that I had put the filter back in that I could explain it. So I did nothing to influence it, and mileage got better.
Best single mileage bet is get a very low cost Tonneau cover. Payoff will still take a good two years, but it has other uses.
Your mileage, if around town is already great. If it's highway, it needs help.
Good luck
Chris
Good luck
Chris
16.6???? I baby my 05 5.4 Screw 4x4, never let the RPM go over 2000 and coast every inch I can and I struggle to stay above 12MPG around town. On the highway I got about 14. Its a new truck so I am hoping it gets better as it breaks in.
How many miles do you have? What kind of driving do you do to get 16.6???
u both should really check to see if there is a reflash that they can do to your computer my 04 screw with 5.4 and 373 ls was getting 15.6 highway and city i had them reflash the pcm and i got 20.4 on the way home that night ( that was babying it) and now i average about 17-18 if i drive semi reasonably 80 and below made a big difference in accleration also
ps mine is 2wd but u should still check into it
As for the K&N, I put one in my 00 f150 4.6L SCAB. Noticed about a 1 mpg gain and the truck was more peppy/responsive.
