Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 08-06-1999, 12:06 AM
Pat Pat is offline
Garage is empty, add now
Pat is starting off with a positive reputation.
clutch/starter interlock switch
  #2 (permalink)
Old 01-23-2001, 01:09 PM
hockeytmc hockeytmc is offline
hockeytmc is starting off with a positive reputation.
I have an 88 f-150 4x4 4.9l , I think i'm having problems with the clutch/interlock switch.Does any one know how to bypass or disarm the switch so that I can verify my problem?
Tim C.
  #3 (permalink)
Old 01-23-2001, 03:53 PM
RGAZ RGAZ is offline
RGAZ is starting off with a positive reputation.
Yep.
Too bad I forgot what to jumper. I'll look at my manual tonight and repost tomorrow.
Basically, you want to remove the grey plug from the black cylinder that is attached to the slave cylinder pushrod. That grey plug has 6 wires on it and you need to jumper two of them to disable the interlock. Can't remember which ones.
I'll get back to you.
Randy
  #4 (permalink)
Old 01-23-2001, 10:30 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Its up to you how you proceed with disabling or bypassing the interlock switch , but remember its there as a safety feature that shouldnt be disabled especially if you have kids around .
  #5 (permalink)
Old 01-24-2001, 07:16 PM
I just want to try and narrow down the problem so that I'm sure that its the clutch/starter interlock and change the part thats not working.
Tim C.
  #6 (permalink)
Old 01-24-2001, 07:18 PM
Thanks Randy I sure could use the help.
Tim C
  #7 (permalink)
Old 01-25-2001, 12:11 AM
Well , What is the problem you are having with your truck ?
  #8 (permalink)
Old 01-25-2001, 01:49 PM
The problem is that I have an intermittent starting problem.Most days it starts just fine but then there are times when nothing happens when I turn the key.All the warning lights come on ,has good strong battery,but not a sound ,no click ,no turnover,dead.I have installed a remote starter into the cab so I can start without opening the hood and jumping the starter relay.Before I start buying parts and taking things apart I wanted to try and jump the starter/clutch interlock switch to see if maybe that was the problem,but I need to know which wires of the switch I need to jump.I have an idea that it may be the starter relay to the elect. control assy. but I'm sure.
Tim C.
  #9 (permalink)
Old 01-26-2001, 04:56 AM
reroy reroy is offline
1985 Ford F-250
reroy is starting off with a positive reputation.
>4.9l , I think i'm
>verify my problem?
> Tim C.
Tim on my 84 Ford the switch is under the dash, it's a plunger switch. I spent 40 dollars on a new switch, tried to install it and I broke the connector. If the wire would have been an inch or two longer it would have been so much easier to replace. So I cut the connector off and bared the ends and wound the two wires together. I know it's a safety device, but it's the only vehicle I have and I needed to get to work the next day. After 16 years of pushing the clutch in to start the truck, I really don't need that switch anyway, I do it with out thinking. When it warms up outside, I'll put a drop of solder on the wires for a better connection.
LeRoy
  #10 (permalink)
Old 01-27-2001, 02:04 PM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
I just finished fixing my own interlock switch. All it needed was to be removed for a cleaning and put right back. It was the grease in the switch that got dirty over the years, and, some WD40 took care of it. To remove the switch, unplug it, then pull down on the release tab at the base of the clutch master and pull the switch back a 'lil. Now turn the switch sideways to reveal the top side. The top is actually the retainer and is released by depressing the 2 tabs at the rear and sliding the retainer backwards until free from the rest of the switch . Now you can pull the switch off the clutch rod. Clean it with whatever cleaner you choose (WD40,brake cleaner or simular, no carb cleaner). You can cycle the switch with a small screwdriver to observe the action and see how the switch works. When you place the switch back over the rod, start by snapping the rear section on the rod as close to the c/master as you can.To snap the front section over the rod, you must depress the mechanism inside the switch (pocket screwdriver)while trying to snap the switch over the rod. You will have to remove the screwdriver before the final snap. Now without disturbing the switch, replace the top retainer, and rotate the switch back to normal and push it against the c/master making sure the release tab engages the post on the switch. Plug the wires and enjoy !
Phil
__________________
Phillip Guidry
Southern,LA
98 F150 2wd 3dr 4.6l Auto 80k
88 F150 2wd LWB 4.9l 4-spd Granny 195k (sold
98 FXDL
83 VT750C
08 Fusion V-6
Tags
1985, 88, bronco, clutch, clutchstart, clutchstarter, f150, ford, interlock, pushing, ranger, replace, starter, starts, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
