Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-03-2005, 01:52 AM
Bob K. Bob K. is offline
Bob K. is starting off with a positive reputation.
How Do I Get Engine Braking In First Gear?
I have a '97 XLT 4x4 automatic. I have no engine braking in 1st gear regardless of transfer case position (4Hi, 4Lo, 2Hi). Regardless of speed--even if I start from a dead stop--as soon as I take my foot off the gas in 1st gear, the tach goes to idle and the transmission goes to "neutral". I do get some engine braking in 2nd and 3rd gears. Others have noted the same "problem".
Some have suggested that overdrive has to be turned off ("O/D OFF") in order to activate engine braking in 1st gear. However, the suggestions seem to be anecdotal and not based on any written fact; it didn't make a difference for me.
Am I supposed to have engine braking in 1st gear? Or, is the Ranger transmission not designed to provide it?
  #2 (permalink)
Old 04-03-2005, 03:53 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
I looked it up in my Ford manual and there are many things that could cause this problem, I suggest getting a manual and going through all the possible causes. Besides the fluid level / condition & the shift cable adjustment all the other possible causes are internal.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #3 (permalink)
Old 04-03-2005, 05:55 PM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE. Peter94 is gaining momentum as a positive member of FTE.
so when your driving the ranger, (94 in my case) and its in first gear, the transmission SHOLD NOT go into neutral and coast when say approaching a stop sign? Is that what your saying?
__________________
88 4x4 300 six, 5spd. granny 1st, reg cab 3.55
85 4x4 5.0L F-One Fiddy Reg Cab 3.55 With a Flatbed
^Now that its 21 years old, it can smoke and drink!^
  #4 (permalink)
Old 04-03-2005, 07:08 PM
captain p4's Avatar
captain p4 captain p4 is offline
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
I had a 99 ranger w/3.0l and never got any engine braking at low speeds, and it hardly ever happened even at higher speeds.
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
  #5 (permalink)
Old 04-03-2005, 11:56 PM
If I manually place the Ranger auto transmission in 1st gear, I expect to get engine braking. Every other automatic transmission I've driven provides this feature in all gears (when selected manually). However, I've heard several others complain that they don't have engine braking when manually locked into 1st gear...almost as if the Ranger transmission is not designed to provide it.
If I know that I'm supposed to have engine braking when manually locked in 1st gear, then I can start looking for a problem.
For example, you're on a long steep hill in the woods and you want to use engine braking instead of riding the brakes. You come to a stop, manually drop the auto transmission down into 1st gear, and let engine compression keep you at a reasonable downhill speed.
Does anyone else know for a fact that his/her Ranger provides engine braking while manually locked into 1st gear?
  #6 (permalink)
Old 04-04-2005, 12:27 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Usually on these when you have no engine braking in manual 1st it's because the valve body gaskets inside the transmission have split and the fluid isn't going where it's supposed to.
The cure is to replace the valve body gaskets.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #7 (permalink)
Old 04-04-2005, 04:21 PM
Peter94's Avatar
Yeah, i dont have that in my ranger. or either its broken. I know my f150 has it though, even when its in drive and it shifts down into say first or second if i'm approacing a stoplight
__________________
  #8 (permalink)
Old 04-05-2005, 12:43 AM
Level2's Avatar
Level2 Level2 is offline
Level2 is starting off with a positive reputation.
I drove many new rangers when I was a car salesman and they all had engine braking in all gears but I have experienced this with F350 diesels. My dads 95 F350 quit doing it after about 180,000 miles but once the transmission was replaced at 230,000 miles it worked again. Some sort of bug in the ford tranny design. My father also has a 2001 F350 PSD and it does not nor has it ever had any kind of engine braking in drive. Overdrive, 1st, 2nd all do but drive itself does not. Never have been able to figure out why.
  #9 (permalink)
Old 04-05-2005, 02:55 PM
nightme_02's Avatar
nightme_02 nightme_02 is offline
nightme_02 is starting off with a positive reputation.
Umm...there is NO such thing as engine braking in a Ford Ranger regardless of year or engine size. My Peterbilt 739X has an Engine Brake (made by Jacobs), but not my Ranger. I believe it to be important to realize this, and even more important to use the correct terms.
I have noticed that the University Vans here in Oklahoma are Chrysler products, and you can put the transmission in 1 (or Low) and drive down the highway at 85Mph. It seems that they (Chrysler) have started to "dummy-proof" their automatic transmissions...maybe Ford has done something similar with theirs!
  #10 (permalink)
Old 04-05-2005, 03:35 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
Gonna be a daddy!!!
2002 Ford Ranger
bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of
Quote:
That's not what he's talking about. He means downshifting like a standard to slow his truck down. But since it's an automatic, his in particular won't do it. Mine does, and it doesn't have a Jake either.
__________________
Joe, who's GONNA BE A DADDY!!! drives an 02 supercab shortbed 3.0 liter automatic power nothing Ranger Edge.
BC Chapter Member
VOTE IN THE FINAL ROUND!!!
  #11 (permalink)
Old 04-05-2005, 09:18 PM
Ken00's Avatar
From the 2000 Ford Ranger manual....
Overdrive
Overdrive is the normal position for most forward driving.
The OVERDRIVE position provides:
l Automatic shifts.
l Apply and release of the torque converter clutch.
l Maximum fuel economy during normal operation.
l Automatic shift 1-3 with O/D canceled.
l Engine braking in 1-3, R. with overdrive cancelled.
Second Position—2nd Gear
The 2nd position provides:
l Second gear start and hold.
l The torque converter clutch may apply and release.
l Improved traction on slippery roads.
l Engine braking.
Manual Low Position
If this position is selected at normal road speeds, the transmission will shift into second gear, then into first when the vehicle reaches a speed below approximately 48 km/h (30 mph).
This position provides:
l First gear operation only.
l Engine braking for descending steep grades.
Coast clutch
The coast clutch is a multi-disc clutch made up of steel and friction plates.
l The coast clutch is applied with hydraulic pressure and disengaged by return springs and the exhaust of the hydraulic pressure.
l The coast clutch is housed in the front brake and coast clutch drum.
l The coast clutch is applied when the TCS switch is on, and 4th gear is inhibited.
l The coast clutch is hydraulically applied when the transmission is in 2nd and 1st position.
l When applied, the coast clutch locks the input shaft to the front planetary carrier, thus preventing the one-way clutch from overrunning when the vehicle is coasting.
l This allows the use of engine compression to help slow the vehicle and provide engine braking.
__________________
Ken
  #12 (permalink)
Old 04-06-2005, 02:15 PM
Peter94's Avatar
will this hold true to the A4LD trannys? I'll check out my ranger manual and see what i can find.
__________________
  #13 (permalink)
Old 04-06-2005, 09:38 PM
Ken00's Avatar
For the A4LD the coast clutch is engaged in 1st and 2nd gear with selector lever in positions 1 and 2. It also engages the overdrive sun gear and thereby the input with the intermediate shaft. In this case the O/D one-way clutch is disengaged and on coasting engine braking takes place.
__________________
Ken
  #14 (permalink)
Old 04-10-2005, 03:09 AM
Thanks for the inputs. It appears that my truck will provide engine braking in 1st gear when the motor is warming up, but once the motor (and transmission, presumably) are at operating temperature, the transmission no longer provides engine braking while in 1st gear.
I've got some more research to do and will try to post a solution here if I find one.
  #15 (permalink)
Old 04-12-2005, 11:29 PM
Level2's Avatar
Talking
Strange.....never heard of a 739X....I have however heard of a 379X. And the engine brake/engine retarder/ Jake (Jacobs) brake is pretty well a standard feature in most over the road trucks these days....hasn't always been the case though. Not what this particular question was about. He was inquiring about engine drag being produced through the transmission. Direct injection diesel engines do not produce engine braking because they are controlled by the amount of fuel injected into the cylinders. Therefore there needs to be a restriction in the exhaust to create a backpressure in the engine to slow it down. Nothing more than a simple butterfly valve in the downpipe from the turbo to the exhaust. A gasoline engine on the other hand has a throttle body which controlls the amount of air allowed into the engine. When the throttle body butterfly valve is closed it creates a vacuum in the engine there-by slowing it down. Since a automatic transmission is basically a hydraulic pump and not mechanically locked into gear like a manual there must be something awry in the way the transmission is being controlled. Just my 2 cents and a little ribbing thrown in for fun!
Tags
032210 , 20102203 , 54 , 5r55e , 5r55w , brake , braking , diary , engine , manual , no , plate , ranger , separator , tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
