Code P0456 - Ford Truck Enthusiasts Forums
Code P0456
Old 04-02-2005, 09:36 PM
miked79928 miked79928 is offline
miked79928 is starting off with a positive reputation.
Code P0456
I need some help with this code guys. The manual says this is an "evap emissions control system small leak". Where is the best place to start checking for this leak? Anyone experience this before? Thanks for the help.
Old 04-02-2005, 11:03 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Mike, first check the gas cap for a good seal. Maybe the O-ring is broken?
The second most likely cause of this code is the evap purge solenoid located above the spare tire. They are prone to corrode.
Error Code PA0093 Fuel System Leak astecasphaltman 6.7L Power Stroke Diesel 16 09-03-2015 09:39 PM
High idle Gerryatrics 1997 - 2003 F150 19 03-30-2014 07:11 PM
p008c code TruckGuy27 6.4L Power Stroke Diesel 1 03-07-2014 07:26 PM
how to check if intake gaskets leak? handyandy91 1997 - 2003 F150 1 01-14-2011 11:17 PM
2000 Mountaineer Evap System Leak merc2000 Explorer, Sport Trac, Mountaineer & Aviator 0 11-25-2007 08:11 PM
Tags
2004, 2005, code, control, emissions, evap, exp, explorer, f150, ford, leak, p0456, po456, sport, system, trac, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
