04-04-2005, 11:12 PM
Well I found the problem. Spark timing was off.
Turns out the distributor was off by quite a bit. What happened was that when the timing belt was off, I changed the fuel pump which caused the auxilary shaft to move which causes the distributor gear to move.
I was using a Haynes manual and it says NOTHING about making sure the auxilary gear is properly set for timing. It talks about the cam gear and crank gear and that's it. I checked through the whole timing belt procedure and distributor procedure and they don't talk about it all.
When I had it apart, I was looking on the aux shaft gear and couldn't find any timing marks and since the book said nothing about it, I didn't worry about the timing because I figured that just the fuel pump ran off the aux shaft. But in the back of my mind I knew something didn't seem right but I blew it off...the book led me astray.
Anyway, I just pulled the dist out of the block and clocked it right and timed it ok.
I've been screwed over by Haynes manuals before so maybe I should have know better, but that sure is a pretty big thing to leave out. And yes, I am using the right manual and was looking at the procedure for the right engine and model year.
Anyway, thought I would share and maybe this may help someone in the future.
