Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #16 (permalink)
Old 04-03-2005, 02:15 PM
RocketScience's Avatar
RocketScience RocketScience is offline
RocketScience has a very good reputation on FTE. RocketScience has a very good reputation on FTE. RocketScience has a very good reputation on FTE. RocketScience has a very good reputation on FTE.
I removed the oil pan (full of oil) on an AT and set it aside under the car. As I skootched around on my back to inspect the valve body, I inadvertently dunked the whole back of my head into the oil pan.
A true IDIOT moment.
  #17 (permalink)
Old 04-03-2005, 04:10 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
RocketScience, that isn't an idiot moment, it is called a hot oil hair tretment. Doing this will keep your hair soft and silky/shiny for a few years.
__________________
2006 Escape XLT V6 4WD
  #18 (permalink)
Old 04-03-2005, 06:19 PM
Ed Willmott Ed Willmott is offline
Ed Willmott is starting off with a positive reputation.
When I was thirteen I wanted to shoot some hoops in the driveway, but moms car was in the way. I convinced her to let me start it like Dad sometimes let me do. The big difference was Dad's was auto, Mom had a stick.
I popped the clutch and almost put the car through the closed garage door. I didn't see allowance money again until I was 16 years old.
__________________
Thanks,
Ed
Ask me why I support FTE!
'99 f250 XLT 4X4 7.3L SD supercab - short bed - 3.73 rear end - boost & pyro gauges -Kwik filter-9k winch - Nak. tri-amp stereo. BF Goodrich 285/75/R16
  #19 (permalink)
Old 04-03-2005, 06:54 PM
duramaximizer duramaximizer is offline
duramaximizer is new and has a neutral reputation at this point.
well i take that back i have done stupid stuff just none of it has hurt.
the first stupid thing i did. i wanted to rotate the tires on my car like every good car stuard. so i jack up the back of the car and put jack stands under it for safety. i move the jack to the front.
i figured i would get in the middle of the front end and jack up the car. well in the process of jacking up the frontend of the car and putting the jack stands under the front end, i find out that it was already setting on the left side before i got the right side under it. so i give the jack a few more pumps and i get the jack stand under there. i look down and see oil. i said a few words and lowered the jack. (i put the jack through the oil pan)
i proceded to call my dad and the junk yard. they had one and we went and picked it up on sat. no problem right. wrong. a front wheel drive car you have to jocky the whole motor to do it.
oil pan 35 dollars
oil dry 5 dollars
labor to put in oil pan 225 dollar
some things money can buy, but learning where not to jack up a car, to save money by rotating your tires yourself. PRICELESS
one more this time in the shop 3k miles later. we have a pit mind you. i am careful to jack up in the right spot on the car. checked that umpteen times. changed oil. lowered jack. went to back it out of the shop i hear something hit the front plactic baffle along with a thud and a splash. my dad start laughing hystarically and motions me on outside. when i come in the shop i realize that i had not moved the oil pan before i had lower the car and that the car didn't have enough ground clearance and knocked the oil plan into the pit.
dad says "You have quite a time don't ya boy."
  #20 (permalink)
Old 04-03-2005, 06:56 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CUSS
1989 Ford Ranger
Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation
I remember a tech at a Japanese car shop that had a drain plug fall into the oil drain pan. His habit was to put it on top of the air filter, and since it wasn't there - he assumed it was all good! (Forgetting that he dropped it).
He test drove it around the block, in the middle of El Cajon California at record speed (it was a 240 Z), only to find the boss standing in the bay he was working out of with the plug in his hand - (the boss had spotted the oil trail leading out of the bay to the street)
"FORGET SOMETHING?"
(He asked, quietly...)
__________________
2009 FTE Online CHAMPIONSHIP
(located in the General Automotive Forum)
ROUND TEN POLL
  #21 (permalink)
Old 04-03-2005, 07:16 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all
well, i was cuttin the springs off a truck, cause i needed the main leaf off them. i was blowing the rivets off and someone came up behind me, i turned around and caught the torch head right on the wrist. luckily i didnt hit the flame or id be missin a peice of my wrist. got a nice burn the shape of a cuttin head on my arm.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #22 (permalink)
Old 04-03-2005, 09:55 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W Mr.Ford 351W is offline
Mr.Ford 351W is starting off with a positive reputation.
umm the Dumbest thing I ever done in MY garage was stepping into oil container, oil
when into my shoes!! AND spilled in the floor, big mess!!
  #23 (permalink)
Old 04-03-2005, 09:58 PM
haroldservice haroldservice is offline
haroldservice is starting off with a positive reputation.
slid the door shut on a van with my thumb inside and the door closed, popped my thumdb like a grape.
__________________
What would you do if you knew you could never fail.
  #24 (permalink)
Old 04-03-2005, 11:15 PM
79 F250 4XoVeRu 79 F250 4XoVeRu is offline
79 F250 4XoVeRu is starting off with a positive reputation.
ive done some pretty dumb things in life
lets see the dumbest things ive done... well i think i have too many to add... but will add a few..
first one pertains to automotive...
i just had gotten my transfercase back from the shop that rebuilt it..spent the time to put it in (by myself,good thing wasnt a very heavy one.just a little in/out box) well got all done and went to test drive it and didnt realize until about a mile from home.. OOOps i didnt put oil in it..well it was shot already so no reason not to drive it home. made it home w/o problem... just a bit of noise. well the next day i went back to the transfer case shop... and told them what i did..needless to say i felt stupid! and of course they were laughing at me. but one good thing came of it,i did end up getting a good transfer case,not one of them in/out boxes. new process 205. and i dont think i will ever forget to add oil to something again.. i always think about it when i am working on something automotive.
well the next one has nothing to do with automotive..but i seen some others similiar.
i was installing some carpet tackstrip on cement one time.. and missed n hit the wrong nail.. yep hit my finger..and blew the end of my finger apart...
also time i almost lost the end of finger using bloody mary knife(carpet knife)
think id learn from it,nope did same thing 2 weeks later on thumb.(these were cuts that required stitches..but i used good ole duct tape... and went back to work
  #25 (permalink)
Old 04-04-2005, 01:17 PM
WhiteBlazze WhiteBlazze is offline
WhiteBlazze is starting off with a positive reputation.
http://josh.leckner.us/Womenlivelonger.jpg
  #26 (permalink)
Old 04-04-2005, 02:32 PM
WhiteBlazze,
Now that's one IDIOT!
  #27 (permalink)
Old 04-04-2005, 03:18 PM
sayno2rice sayno2rice is offline
sayno2rice is starting off with a positive reputation.
Lightbulb
I was doing an engine swap in my buddies back yard on a Ford Thunderbird. We set the drive train from the donor car on the ground then proceeded to jack the car up about 4' off the ground. We took another car and a chain and pulled the drivetrain out from under it. My buddies intelligence was running wild that day and he decides it would be awesome to cut this car in half with a sawzall. It wouldn't have been so bad except that he started cutting the car while it was on jackstands, blocks, and old wheels still 4' off the ground. So he is inside the car cutting through the floor board when I noticed what he was doing. Before I could get to him to tell him to stop, WHAM! When he got all the way through the floor, the roof buckled, sunroof busted on his head, and the car fell to the ground (almost). He ended up with 4 large cuts and 127 stitches from the roof glass in his head. Not to mention what a time we had trying to recover my jackstands after that. Needless to say, I didn't ask him to help me put the drivetrain in the new car.
  #28 (permalink)
Old 04-04-2005, 06:08 PM
Quote:
Originally Posted by RocketScience
WhiteBlazze,
i have seen that done in real life. i was in costa rica for a spanish club trip.
i thouhgt it was ingenious considering what they have to work with for tools.
if you ever saw one of their gas stations you would get my drift.
  #29 (permalink)
Old 04-04-2005, 06:19 PM
you and i must belong to the same hmo, that's what i did. :{)
__________________
  #30 (permalink)
Old 04-04-2005, 08:59 PM
WhiteBlazze,
BTW....that's not me!!
Tags
bodygaurd , motorcycle , movie , my , rwh776
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
