what is the Distributor/timing specs for a 460
Old 04-01-2005, 08:49 PM
Pwrstrkn's Avatar
Pwrstrkn
Pwrstrkn is offline
Question what is the Distributor/timing specs for a 460
I have a 94 Ford F350 with a 460 that I need to retard the distributor/timing. Does anyone know the specs?
Thanx
Dusty
Old 04-06-2005, 07:50 PM
Rotor's Avatar
Rotor
Rotor is offline
I have a 88 with a 460. I am between 10 and 14deg BTDC at 750rpm idle. Since this is all comp/vacum controlled I can't narrow it down any more than that. Hope this helps, Karl...
Old 04-06-2005, 08:54 PM
tex94F250's Avatar
tex94F250
tex94F250 is offline
10° BTDC with spout removed. You cannot take and accurate reading with the spout connected.
Old 04-13-2005, 12:38 AM
ckdc's Avatar
ckdc
ckdc is offline
I've got a 90 with a 460 that knocks if I don't use 93 Octane. Can I retard the timing to 8 degrees and use regular 87 octane? I use it to tow my boat. I'm pulling about 10,000 lbs.
Old 04-13-2005, 06:08 AM
tex94F250's Avatar
tex94F250
Retarding the timing might help. I'd try running a can of Seafoam through the fuel tank and another through the vacuum booster line to help remove some of the carbon build-up in the cylinders/intake system. Most pre-ignition in older vehicles is due to residual heat in carbon deposits in the combustion chamber. At about $5.00 a can, it's well worth a try before going with the timing adjustment.
Old 02-10-2013, 09:49 PM
likefords's Avatar
likefords
likefords is offline
I have 1986 f250 with 460,the last yr for carbs. they came with 2 air pumps n air injected in the exhaust,ran like ****,high idle n no power,had all kinds of vacumn leaks.In-laws bought it new.removed vacumn pumps2 n replaced exhaust with earlier manifolds.Replaced the timing chain with 1970 chain,they are not retarded 6degrees from the factory.replaced intake with one without ERR plate. I run 10degree timing n 87 octane.also the dist.has way to much vacumn,thats why she rattles under load. dont know about F.I. models
The following users liked this post:
Old 02-11-2013, 01:07 AM
mdh1701's Avatar
mdh1701
mdh1701 is offline
Disconnect the spout, check the initial timing with a light, should be 8* BTDC stock, if you're good there then suspect other problems. If it is advanced more than 8* someone may have messed with it before, these engines like 12* BTDC so I would think another problem is causing your preignition. Good luck!
Old 02-11-2013, 05:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
First off;
This is an eight year old thread...
1987 was the last year for Carb's.
There is no spout with a carb and DSII system.
10 degrees is stock, I'm at 12 with no problems.
If you have an issue with knock, point the finger at yourself for removing the EGR spacer.
As for advance, just get yourself a Crane Cams adjustable advance unit and follow the instructions.
Firetankerf500
04-18-2017 03:10 PM
cjben
09-03-2015 12:01 AM
bills86f150
10-22-2014 12:22 PM
LARIAT 85
02-23-2014 03:29 PM
rusty brown ford
New Member Introductions
09-08-2007 07:12 PM
Quick Reply: what is the Distributor/timing specs for a 460
