what is the Distributor/timing specs for a 460 - Ford Truck Enthusiasts Forums
Old 04-01-2005, 09:49 PM
Pwrstrkn Pwrstrkn is offline
Pwrstrkn is starting off with a positive reputation.
Question what is the Distributor/timing specs for a 460
I have a 94 Ford F350 with a 460 that I need to retard the distributor/timing. Does anyone know the specs?
Thanx
Dusty
Old 04-06-2005, 08:50 PM
Rotor Rotor is offline
Rotor is starting off with a positive reputation.
I have a 88 with a 460. I am between 10 and 14deg BTDC at 750rpm idle. Since this is all comp/vacum controlled I can't narrow it down any more than that. Hope this helps, Karl...
Old 04-06-2005, 09:54 PM
tex94F250's Avatar
tex94F250 tex94F250 is offline
tex94F250 is starting off with a positive reputation.
10 BTDC with spout removed. You cannot take and accurate reading with the spout connected.
Old 04-13-2005, 01:38 AM
ckdc's Avatar
ckdc ckdc is offline
ckdc is starting off with a positive reputation.
I've got a 90 with a 460 that knocks if I don't use 93 Octane. Can I retard the timing to 8 degrees and use regular 87 octane? I use it to tow my boat. I'm pulling about 10,000 lbs.
Old 04-13-2005, 07:08 AM
tex94F250's Avatar
Retarding the timing might help. I'd try running a can of Seafoam through the fuel tank and another through the vacuum booster line to help remove some of the carbon build-up in the cylinders/intake system. Most pre-ignition in older vehicles is due to residual heat in carbon deposits in the combustion chamber. At about $5.00 a can, it's well worth a try before going with the timing adjustment.
Old 02-10-2013, 10:49 PM
likefords likefords is offline
likefords is starting off with a positive reputation.
I have 1986 f250 with 460,the last yr for carbs. they came with 2 air pumps n air injected in the exhaust,ran like ****,high idle n no power,had all kinds of vacumn leaks.In-laws bought it new.removed vacumn pumps2 n replaced exhaust with earlier manifolds.Replaced the timing chain with 1970 chain,they are not retarded 6degrees from the factory.replaced intake with one without ERR plate. I run 10degree timing n 87 octane.also the dist.has way to much vacumn,thats why she rattles under load. dont know about F.I. models
Old 02-11-2013, 02:07 AM
mdh1701 mdh1701 is offline
mdh1701 is starting off with a positive reputation.
Disconnect the spout, check the initial timing with a light, should be 8* BTDC stock, if you're good there then suspect other problems. If it is advanced more than 8* someone may have messed with it before, these engines like 12* BTDC so I would think another problem is causing your preignition. Good luck!
Old 02-11-2013, 06:46 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
First off;
This is an eight year old thread...
1987 was the last year for Carb's.
There is no spout with a carb and DSII system.
10 degrees is stock, I'm at 12 with no problems.
If you have an issue with knock, point the finger at yourself for removing the EGR spacer.
As for advance, just get yourself a Crane Cams adjustable advance unit and follow the instructions.
460 long crank times? cjben 1987 - 1996 F150 & Larger F-Series Trucks 6 09-03-2015 01:01 AM
Distributor and Timing Questions LARIAT 85 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-23-2014 04:29 PM
351m distributor in a built 460. Blown 331 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 07-04-2010 03:11 PM
460 tuning differences yr to yr peganit2 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 08-29-2009 11:00 PM
distributor problems again darrin1999 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 03-01-2008 11:59 PM
Tags
460, 94, correct, distributor, ford, specs, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
