You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well 3 years after i got this truck i finally have the lighting problem whipped. After patching and chasing and fixing this and that, i even replaced the headlight switch i finally figured it out. the entire problem was in the steering colum. why on earth would so much crap be shoved up in there and expected to work forever ? after patching the wires in there and replacing a few that were rubbing i thought i had the problem solved, but alas as soon as i put it back togather the brake lights quit working again, so i tore it apart again and again and again. I finally see that the turn signal cam isn't sitting where it is supposed to be sitting. Seems the little nub that holds it in place is gone and it is kinda floating around a little. It couldnt be this that is causeing my problems i thought, so i held it in place and called my daughter over to look at my lights. sure enough everything worked, as soon as i let go i only had running lights again. so i called lmc and two days later ( which is today april 1st) i get a 49 dollar package containg a new turn signal switch, snip snip run some wires hook them up and WOW all my lights are now working perfectly. If only everything was that easy. But of course as i was testing all my lights i see that i have a broken headlight, must have happened when that gravel truck passed me on the way home. so off to walmart to get a headlight. It never ends !
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
I had a 70 Chevy that was similar, it depended on which way the turn signal was last moved as to which brake light worked, but it was never both at the same time. The truck wasn't worth the money to get a replacement switch for it...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
it didn't have a straight panel on it, no bed floor, and the carb gasket was installed upside down. It eventually burned up due to a gas leak at the carb onto the exhaust manifold... stupid thing to put the exhaust under the carb on a straight 6...
__________________
