460 fuel milage question.
I have a 87' F-350 4X4 dump, 460 and a C4 auto trans. The light weight is 8500# and I'm getting 5 to 6 miles per gallon. I've since changed the Holley carb to a Edlebrock with no change to the economy, is this what I can expect or is something wrong?
Thanks in advance...
Tony
Tony
Two things against any decent mileage here, 460 CID doesn't help, but the weight of the truck is one and I will bet it has a low rear end ratio (high numerically) is two. My '84 F250 superduty, suercab with 4.10's is up to 9+ mpg after exhaust, dist. and mods tothe stock carb (soon to be replaced).
I get 8-10 highway, 4-6 around town on my '83 F350 (10,000 GVWR) flatbed dump with 460, C6, 4.10, and A/C after rebuilding the stock Holley 4180C-4V carburetor. Previous owner had really screwed up the carb including messing up the choke, drilling out the main jets and installing the wrong power valve. Holley has a really good technical service on-line; I gave them my part # and list # (taken directly from the carburetor casting) and they replied with the proper jet # and power valve #. All the emission systems are stock and operational. My base timing is 10 BTDC rather than 8 BTDC as called for on the sticker. The proper power valve for your specific vehicle is very important for optimum gas mileage; those that come with the rebuild kits are generally "one-size-fits-all". Piffery1
Went with 2 1/2 badck to the muffler, which is 3" and 3" tailpipe. I still have the stock dist. I changed the advance curve from the 18 degrees in the dist, 36 degrees on the crank to the 13 degree dist curve and 26 degrees on the crank. Bumped initial timing from 6 to 8 degrees and put another light spring on the advance weights after removing the heavy one, but made the second one fairly tight. Total advance at 34 degrees in by 3500 rpm. The vacuum unit stayed stock and connects to ported vacuum on carb. No ping on regular and picked up almost 1 1/2mpg. The exhaust gave me 2 mpg.
Brett1322
12-13-2016 10:35 PM
vinnydiesel27
03-18-2016 08:46 PM
66_f100_460
15
09-01-2001 08:31 AM
