leaks in rear end
no.
take it to the dealer. there may be a small leak from a brake line, or the plug may not be tight (check it ) or there could be a problem with the rear end. either way the dealer should look at any oil around the rear end. your rear axle should never have oil leaking from it anywhere. it isn't something leaking from something else is it?
