Thanks for the picture Wizardvette. Your truck looks great. Over here in Toronto it's a nasty day as well. Did you go with the tape that was supplied or did you attach the scoops a different way? Also, how did you know where to space them apart? Thanks again.
I used the adhesive that was supplied. As for spacing, I guessed the distance between the actual scoops, but as for placement on the hood, I measured and hung strings where they were to be set. It's easy to find the center of the hood, then you can work from there.
The are Hoods made of HD Reynolds wrap, stretched across the ribs. If you ever fall into one, don't even ask , it will look like you wrapped a Baked potato with it and then placed it back on the hood.
