Rear disc brake removal ?? (rotors stuck and wont come off) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-30-2005, 05:32 PM
BltFordTough's Avatar
BltFordTough BltFordTough is offline
BltFordTough is starting off with a positive reputation.
Hey Guys, I am working on my 2002 superduty. Working on a rear disc brake job and i cant get the dang disc's off!!! Any tips on how to do this ??
Thanks in advance.
Ryan
Old 03-30-2005, 06:11 PM
Cuda444's Avatar
Cuda444 Cuda444 is offline
Cuda444 is starting off with a positive reputation.
Just take a block of wood, hold against the back of one side of the rotor and tap it a few times, switch sides, top, bottom, with a hammer... it should just wiggle off... I dunno if you've tried it yet, but that's how I usually do it
Old 03-30-2005, 07:56 PM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
I just changed the E-brake shoes on my 97' Expedition today, rear disks, to remove the rotor,,,It did'nt want to come off, so I placed a pry bar( large screw driver) between the caliper bracket and rotor, applied pressure to bar and with a hammer hit the rotor near the center between the wheels studs,,that sucker popped then ! Then just had to wiggle it a bit,,the e-brake had come apart, and locked up the wheel,,so had to do it. I think the Superdutys are about the same setup,,but bigger. Good luck !
Later,,,,,,,,Mark
Old 03-30-2005, 11:13 PM
Kostiuk Kostiuk is offline
Kostiuk is starting off with a positive reputation.
I just did the rear brakes on mine and they were rusted on really bad. I beat the crap out of them with a dead blow hammer and couldn't move them. I finally fired up my air hammer and used it on the rotor all around the wheel studs. That loosened them up and I was able to work them back and forth to get them clear of the e-brake shoes.
Old 03-31-2005, 05:24 AM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
heat
if you have a red and green set. heat the area around the axle center untill you hear it pop then pull them off. its a old drum trick that still works. i have done it at home with a propane torch just takes longer
Old 03-31-2005, 09:28 AM
Frobozz Frobozz is offline
Frobozz is starting off with a positive reputation.
If you're replacing the rotor anyway, then beat the living crap out of it from the back with a sledgehammer. That pops it right off after a couple of blows, and badly mars the rotor surface in the process. Remember to smear a little anti-sieze on the hub pilot hole of the new rotor before putting it back. (And of course smear the anti-sieze on the hole in the alloy wheels if you have them!)
As a marginally-related aside: I have a 2003 F250 4x4. I assume the front rotors pop off the same way, i.e. no need to undo wheel bearings or anything? I think mine just have pad material on them which I'll try to clean off, but if they're actually warped then it's replacement time.
Duncan
Old 03-31-2005, 01:06 PM
DZari's Avatar
DZari DZari is offline
DZari is starting off with a positive reputation.
Just like the dead blow hammer, I use a five pound rubber mallet and beat around the edges of the rotor to set up a harmonic and POP off it comes.
Old 04-01-2005, 12:55 PM
Quote:
Answered my own question yesterday: yep, the fronts are put together just like the rears. Except, surprise surprise, Ford actually slathered anti-sieze lubricant all over the back side of the center of the front rotors, unlike the rears! They just dropped off in my hands once I got the caliper out of the way.
My fronts weren't as warped as the rears but they were all warped, at 45K miles. The pads were way less than half worn. I live in the flattest area you can imagine, not a lot of stop and go traffic, don't haul a heavy trailer (some trailering and bed payloading, but nothing extreme) I don't ride my brakes, I always torque my own lugnuts and the last time the wheels were touched was at 20K miles anyway. The factory rotors are just junk. I hope the enlarged brakes on the 2005 and up trucks finally fix this problem.
Duncan
Old 04-01-2005, 05:20 PM
Thanks for the help guys. I was able to get it off by hitting the part by the lug nuts with a hammer to losen it up and then using a big bar to pry against the caliper bracket to pop it off.
Thanks again!
Old 11-22-2012, 10:54 AM
Charlie77 Charlie77 is offline
Charlie77 is starting off with a positive reputation.
Hi,
I'm new and while this is an old thread, thought I would toss in my 2 cents. MY 98 Explorer rear rotors were stuck as if welded. So, I asked my mechanic his trick. He chuckled and asked where I was pounding on the rotor. He said that the only place to hit which would work was on the flat part between the studs with a pretty big hammer... but don't hit the studs.
With the studs heavily on my mind I was a bit nervous about big whacks. There had to be a way to whack and protect the studs. My solution was low tech and worked nicely. What I did was cut 3 inch lengths of PVC pipe and put one over each stud. To keep the PVC from bouncing off I stuffed a small amount of paper towel in when I put them over the studs.
The PVC pipe protected the studs from both direct hits and glancing blows. In compression it's quit strong and I actually did hit one. Because the PVC is larger than the stud, a misdirected blow sends the energy to the rotor, not the stud. The PVC did not break.
And yes, I used a 4 lb hammer and heavy blows.
IT WORKED!
Dave
Old 11-22-2012, 11:05 AM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
Get 2 long bolts the same thread as the caliper slide bolts. Thread them from the back side deep enough that they contact the disc to "press" the disc off.
Old 11-22-2012, 11:37 AM
Quote:
That did not work, nor did the wheel puller nor did drilling and tapping the face of the rotor and using a steel bar on the hub tightening the bolts. The bar, 3/8 X11/2 just bent.
Dave
Old 11-22-2012, 12:29 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I use a brass punch and then wack inbetween the studs. The punch is already in contact with the surface and therefore the studs are fine.
I use a 5lb hammer. Takes about three/four wacks at most.
PB blaster of course generously applied the minute the wheel comes off.
Old 11-22-2012, 12:54 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
Put anti seize o the hub surface before re-install of the new one and you shouldnt have any problems again. Also make sure your parking brake is released since the design is dumb IMO on our trucks.
Old 11-22-2012, 01:03 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
Quote:
Thanks in advance.
Ryan
BETTER WAY to REMOVE ROTORS
http://m.youtube.com/watch?v=mtsTJCRljAs&desktop_uri=%2Fwatch%3Fv%3Dmts TJCRljAs
Rear Disc Brakes GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-09-2015 12:21 PM
1976 f250 disc brake conversion? ryan a Brakes, Steering, Suspension, Tires, & Wheels 1 06-03-2014 03:04 AM
Disc brakes front and rear? SuperDuty93 1957 - 1960 F100 & Larger F-Series Trucks 6 12-14-2013 09:30 PM
rear disc brake conversion???? JetBlackBronco 1978 - 1996 Big Bronco 47 05-13-2008 11:39 AM
Rear Disc Conversion i0n 1978 - 1996 Big Bronco 1 10-22-2003 02:10 AM
Tags
brake, disc, rear, rotors, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
