Hesitation
Old 03-30-2005, 11:47 AM
blu98ta's Avatar
blu98ta
blu98ta is offline
Hesitation
MY dad has a 98 f150 that he bought from his company recently. It has 140,000 miles on it. HE has been telling me that he is noticing a hesitation when he gets on the freeway, or even just speeding up. I rode in it the other day and there is a hesitation, but then it will decide to go. What do yall think is wrong? Injectors, plugs and wires?
Old 03-30-2005, 12:14 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-30-2005, 01:35 PM
blu98ta's Avatar
blu98ta
blu98ta is offline
Can anyone help us? Also does anyone have a right up on how to change the injectors if that is what needs to be done, cuz I'm used to working on my TA and haven't touched his truck yet.
Old 03-30-2005, 01:37 PM
92merc's Avatar
92merc
92merc is offline
I'd be looking into replacing the fuel filter. That's a fairly easy place to start. Usually a really plugged filter will through a code, but maybe you're not that bad yet.
Old 03-30-2005, 01:54 PM
blu98ta's Avatar
blu98ta
blu98ta is offline
He told me that he just did that.
Old 03-30-2005, 08:18 PM
fordguy21's Avatar
fordguy21
fordguy21 is offline
Try some seafoam
Old 03-30-2005, 08:23 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
What size engine does it have?
How many miles on the spark plugs?
Old 03-30-2005, 10:55 PM
ET1's Avatar
ET1
ET1 is offline
Have you seen any improvement? I also experienced the same problem and that's what the mechanic advised me to do.
While there was an improvement, I still occasionally experience some hesitation especially if I'm running my truck at a constant speed for a while. The mechanic has already checked the vacuum and it seems that all are in good order. I'll see if things would improve if I'll change the plug wires.
Old 03-30-2005, 11:16 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
ET1 have you cleaned your MAF sensor?
Old 03-30-2005, 11:53 PM
Perfection's Avatar
Perfection
Perfection is offline
is the MAF on this truck the same as on other vehicles? 220ohm resistor = fool ECU into thinking there is more air = More HP ?
Old 04-02-2005, 04:56 PM
blu98ta's Avatar
blu98ta
blu98ta is offline
Originally Posted by fordguy21
Try some seafoam
Should I do it through the brake booster line? That is where I did it in my car. Oh Racerguy it is a 4.6 with 140k, and I believe that the spark plugs and wires have not been changed yet.
Old 04-02-2005, 08:17 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
If there is any question as to how old the plugs are then they should be replaced and then go from there if it still isn't how it should be.
Today I worked on a truck that the customer's complaint was a lack of power.
It was missing so bad under heavy throttle that I could barely get up to highway speed. At cruise it ran good.
The plugs were really bad and 2 of them were rusty. I replaced the plugs, cleaned the COPs and MAF and it ran like new again.
Old 04-04-2005, 02:16 AM
ET1's Avatar
ET1
ET1 is offline
I already did. I haven't changed my spark plug wires, though.
Old 04-07-2005, 11:09 PM
blu98ta's Avatar
blu98ta
blu98ta is offline
Where should I put the seafoam in the motor? Can I use the brake booster line like I did on my car?
JethroF250
04-07-2014 07:17 AM
granitepro78
1997 - 2003 F150
10-13-2012 12:07 PM
bigmack
1997 - 2003 F150
08-17-2006 08:51 AM
ryanstruck
3.8 & 4.2L V6
10-29-2001 12:14 PM
Quick Reply: Hesitation
