Here Is The Dill
Here Is The Dill
i have got a bit of a pickle. I have got a 1968 F-100 that somebody changed the motor from a inline 6 to a FE motor. After doing my homework i learn that this motor is a 352 that came in a 64 t-bird ( cant find what motors came in the t-birds that year). so i know what motor it is but now i would like to know as far as my options what can i do with this motor to beef it up some. It has a 4 speed behind it. This drive train is going under a 56 F-100.
What can i do and what parts will i need.
thanks for any help
-Brandon-
thanks for any help
-Brandon-
I believe 390's were available in the Birds as well. Do a stroke check on it and verify the displacement. You can always build it up to a 390, if it's not. A 352 can be rodded out just like any other motor. This however will need to be accomplished with some high compression to do the trick.
--Mike
--Mike
ohhhhhh i am so confused this **** is driving me crazy. hmmmmmm well this is what i have got but you cant fail with a good old dowel to messure that stroke. i will try that this after noon but from the best that i can tell i found an id tag on this motor it says it is a 352 out of a 64 but that was all that i could read i will take this tag off and clean it to see what i have got for sure
Thanks for all
PS this motor is in great shape. no smoke no knocking no slapping no pinging
Thanks for all
