98 f150 electrical problems. - Ford Truck Enthusiasts Forums
Old 03-30-2005, 01:13 AM
AirSmitty's Avatar
AirSmitty AirSmitty is offline
AirSmitty is starting off with a positive reputation.
I have a 1998 f150 4x4 with a 5.4. The gas gauge is always stuck on full, and my four wheel drive will not engage. Has anyone experienced these problems? Is it a matter of fuses or something else? Thanks in advance.
Old 03-30-2005, 10:34 AM
xallxforxchristx xallxforxchristx is offline
xallxforxchristx is starting off with a positive reputation.
hmm...I'm not really much for electrical yet, but isn't there a sensor that sort of floats in the gas tank that tells you how much fuel you have? You might check this, it could be stuck in the full position.
Old 03-30-2005, 10:53 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
It could be fuses but I dont think fuel gauge and 4x4 are tied into the same circuit. But doesn't hurt to check the fuses tho. And don't forget to check the fuses under the hood as well.
Old 03-30-2005, 12:53 PM
FordPickupMan351w FordPickupMan351w is offline
FordPickupMan351w is starting off with a positive reputation.
Somebody please correct me if I am wrong but a constant full fuel guage indicates either a bad sending unit or bad ground to the sending unit. Do you have a manual 4x4 lever or the on the fly switch?
Old 03-30-2005, 07:00 PM
AirSmitty's Avatar
The 4x4 is switch on the fly.
Old 03-30-2005, 08:52 PM
QC guy QC guy is offline
QC guy is starting off with a positive reputation.
I don't know if the two problems are related or not. I know in PA we have had some "bad" gas recently that has ruined a lot of sending units in all makes of vehicles. This has something to due with the chemical composition of it. Have you heard anything like this in you area?
As for the four wheel drive...the actuator might not be engaging. You can check this by removing the cover and having some one turn the swith while you watch the piston. Have to be careful though because the engine needs to be running. I just replaced one on a 98 for this reason.
Defrost problems jcfcoyle Cooling, Heating, Ventilation & A/C 2 01-12-2015 05:52 PM
Are 2004 f150's that bad? Dangwillo 2004 - 2008 F150 10 01-06-2015 01:08 PM
engine swap klocker97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 06-05-2014 08:34 PM
radio slayer67 2004 - 2008 F150 0 05-25-2014 03:59 PM
2013 f150 technomon 2009 - 2014 F150 2 02-12-2014 08:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
