Escape Lift Kit? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape Lift Kit?
Old 03-29-2005, 12:51 PM
AmbnGnt AmbnGnt is offline
AmbnGnt is starting off with a positive reputation.
Escape Lift Kit?
I was trying to find a lift kit for my Escape and all i could find was a 1 inch lift, and i found a 3 inch body lift. Does anyone know of a company that makes lift kits for an Escape?? i was also wondering if some one could tell me if a body lift is bad for the vehicle....i thought i heard that they were not good but am not sure... Thanx
Old 03-29-2005, 06:39 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 03-30-2005, 02:33 AM
echoy97 echoy97 is offline
echoy97 is starting off with a positive reputation.
I guess if you lift it, you have more chance of rollover and die.
Old 03-31-2005, 06:54 AM
DoctorCAD DoctorCAD is offline
DoctorCAD is starting off with a positive reputation.
Can't use a body lift on a uni-body vehicle. There is no frame to stick the hockey pucks on top of.
H & R makes a 1" and BDS makes a 2" lift.
And...if the lift kit is a well engineered kit, the chance of roll over is not increased.
Just keep in mind that these vehicles are not hard core 4-wheelers and a lift will not make them any better at it.
Old 03-31-2005, 09:58 PM
Saurian's Avatar
Saurian Saurian is offline
Saurian has a good reputation on FTE.Saurian has a good reputation on FTE.
Any lift kit raises the center of gravity and increases the chance of rollover in avoidance maneuvers. Unless somebody's found away to lower the C.O.G. and raise the truck.
A properly designed lift kit will still give you handling characteristics to normal, maybe. Usually a bit stiffer.
Old 04-01-2005, 07:03 AM
I had a Suzuki Samurai, the one that started the rollover scare back in '88. It had an extremely bad suspension from the factory, no more than 3/4" front spring travel, that is what made it rollover prone, and I could feel it in tight turns bottoming out. I had a 3" Rancho lift installed and all of that went away. The increased spring travel and heavier shocks would keep the tires glued to the road in most cases, way better than the stock suspension ever could.
Old 05-15-2010, 09:40 AM
lemos80 lemos80 is offline
lemos80 is starting off with a positive reputation.
Question Escape off tires
Will 31x10.50/15 or 30x9.50/15 tires fit on Escape 4x4 lifted 1.75inch with no rubbing?
Old 06-03-2010, 08:29 AM
colli1979 colli1979 is offline
colli1979 is starting off with a positive reputation.
i donīt know if itīs actuell, but here in germany eas once an maverick/escaope with an 2" lift from Old Man Emu
Old 06-03-2010, 08:31 AM
if it is actually soon:
last year iīve seen an ī02 maverick / escape with an 2" OldManEmu lift
Old 06-04-2010, 05:55 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
Keep in mind that the Escape has four half shafts (eight CV joints). I would not install a lift kit in an Escape for that reason alone.
Old 04-20-2015, 04:47 PM
Ottoknut Ottoknut is offline
Ottoknut is starting off with a positive reputation.
Escape lift kit
Old Man Emu makes a suspension lift kit for Escapes. The kit gives a safe 1.75" lift, and is available through Rocky Road Outfitters: Ford Escape Lift Kit: OME Ford Escape Lift Kit I'm thinking of trying the kit out on my '05.
Old 04-20-2015, 07:57 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
I would look i to this if my Tribute wasn't 11 years and (still) 288k miles. I'm just not sure putting $300 worth of springs under it would be wise. But then again, I have noticed it does seem to sit slightly lower than most others.
Old 04-21-2015, 10:07 PM
Airbrush's Avatar
Airbrush Airbrush is offline
Airbrush is starting off with a positive reputation.
You're going for extreme CV joint wear?
Old 05-20-2015, 11:22 PM
Fordman79's Avatar
Fordman79 Fordman79 is offline
Fordman79 is a splendid one to beholdFordman79 is a splendid one to beholdFordman79 is a splendid one to beholdFordman79 is a splendid one to beholdFordman79 is a splendid one to beholdFordman79 is a splendid one to beholdFordman79 is a splendid one to behold
I'm a little curious about doing a lift kit on my Escape. I would like to know how it works out and how you like it if anyone does it.
Old 07-12-2015, 09:06 PM
Cameron Hicks Cameron Hicks is offline
Cameron Hicks is starting off with a positive reputation.
Hey im interested in the 3in lift. Do you still have any info on where to get one?
Want to lift my 1977 2wd f150 Jculv 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-18-2016 11:42 AM
Susension lift kit for 71 f250? lilsmokey 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-26-2012 11:48 PM
lift kit ?s metalskater2 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-20-2009 12:28 PM
lift kits for explores imchrislara Explorer, Sport Trac, Mountaineer & Aviator 2 06-17-2006 06:05 AM
body lift??? hotmod046 Offroad & 4x4 3 03-18-2004 11:46 AM
Tags
08, 2002, 2003, 2008, 2009, 2wd, escape, ford, kit, kitpics, kits, lift, lifted, lit, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
