Daul Exhaust f250
I had a CAT back system mad at my local Midas shop. The system has Flowmaster mufflers and 18" stainless exhaust tips. I have the system exiting out the back rather than behind the rear wheels. Performance is up slightly and the sound is great. This Midas shop happened to have a guy that was really good on the tubing bender and the number of bends is minimal. The through exhaust diameter is 2.5". I hope this helps.
Dual exhaust
Try this website: http://www.mufflerandperformance.com...gory_Code=Ford
They aren't cheap, but they say they have them.
If you're handy with a sawz-all and a welder you can adapt any dual system for your truck... Mine (gallery) was off a dodge longbed... dual out the back... a few cuts and rewelds and it comes out the corners just fine... you may lose your spare though, I did... But it was worth it All I did was buy a 3" in and 2.5" out magnaflow and 2 18" tips and welded it all together... if you find a truck with the same bed length as yours they're more or less all universal... in my case 8ft bed (pretty standard)
Hope this helps!
Hope this helps!
Looks like from the other post's I will have to get one custom made. The daul's I have seen fabricated on the gassers looks like the spare will have to be removed or melt.
I have checked several manufactures. It seems if you have the rear sway bar and a 16" spare tire mounted under the truck like I do. Your only bet is to get one custom made. Borla says they make one for $800.00. I can get a custom made for about $250.00. I'm not looking for any tips just duals out of the muffler tail pipe. I don't have a welder or bender. So it looks like I will be paying a shop to fabricate the pipes for me.
Thanks for all your input..
dual exhaust
Here's another place that says they have them for the V8's.
http://www.pacesetterexhaust.com/predator.htm
Good luck.
Good luck.
rlbrons
18
01-22-2012 05:56 PM
cookster
07-18-2006 02:27 PM
ltj427
12-25-2005 07:16 PM
joecool
1999 to 2016 Super Duty
07-17-2001 08:13 AM
