Onboard air
I have installed an Oasis XD2000 compressor and an 8 gal tank with universal quick couplers in front and rear bumpers as well as ARB lockers in front and rear differentials. The compressor is powerful enough to run air tools and inflate a 35" tire from 0-45 psi in little over a minute. Air bags will be installed when I get my camper. You can find the compressor at onboardair.com or oasismfg.com
Originally Posted by 569104
zenitram,
Yeah the compressor is not cheap and not for everyone...but depending on how much you intend to use it and what for... the added cfm, duty cycle and time savings can be worth it. Its like having a shop air compressor on your truck. It was worth it to me.
It seems that these have a high current draw. Does the normal idle handle the electrical needs when in use? I'm guessing that you don't want to use this when the truck is off.
One other question; Since you mount it under the truck, how do you keep the intake filter clean? What about when it rains, or gets muddy, sandy...
Thanks
zenitram,
The oasis does have high current draw when compared to most of the others, however, because of the higher volume it runs considerably less and completes the job a lot faster. Normal idle on my truck handles the electrical needs just fine in most cases. I have dual batteries (in parallel..12v) and dual altenators but under heavy use I use my Aux Idle Controller to increase idle to maintian max voltage/amps.
I do not advise running the compressor without the truck on...hard on battery(s). To cure the muddy, sandy & water problem I routed intake filter and crankcase breather to a protected area away from the elements, ie. under the hood and/or high under center of the truck next to body. Also, I built a 3/8" steel skid plate/splash guard/rock protector for the compressor and mounted it so the compressor is above the bottom of the frame.
Hope this helps.
Hope this helps.
dtgl90vt
08-16-2013 10:03 PM
Steve_Uzi
Offroad & 4x4
04-22-2001 11:35 PM
